Brake upgrade from 2 piston to 4 piston
Old Jan 19, 2026 | 09:25 PM
borincanodv@yahoo.com's Avatar
4th Gear
Default Brake upgrade from 2 piston to 4 piston
Hi
looking for some help and guidance. I came across new orange painted front 4 piston chippers from a friend whom upgraded to 6 piston. Is it possible to upgrade from 2 piston calipers to 4 piston on a 2023 110 S? Has anyone else completed this upgrade? Dealership would not help. Thank you in advance for your help.
Old Jan 20, 2026 | 08:28 AM
CincyRovers's Avatar
Should be a fairly simple swap, as P300s with 22" wheels come with the Brembo four-piston calipers.
You would need to also get the larger rotors, though.
Old Jan 20, 2026 | 12:41 PM
4th Gear
Thank you for the reply. Mine came with 20 inch wheels and twin piston fronts. Is 4 piston stall with larger rotors possible?
Old Jan 20, 2026 | 01:30 PM
Yes. If you're on 20" wheels, it will be fine. On P400s (which come with the four-pistons), 18" wheels will not clear the larger rear calipers unless you grind them down or swap them out with a smaller caliper. Hence why the 19" wheel is the smallest wheel on the P400. V8s have even larger brakes and won't clear anything less than a 20" wheel.
TyTyBinks
May 12, 2021 12:08 PM
Externet
Mar 27, 2015 12:33 PM
coldstart
Feb 25, 2013 11:51 AM
bballjames
Sep 10, 2012 01:48 PM
Ranchrover
Jul 18, 2008 11:39 PM
