Brake upgrade from 2 piston to 4 piston
Hi
looking for some help and guidance. I came across new orange painted front 4 piston chippers from a friend whom upgraded to 6 piston. Is it possible to upgrade from 2 piston calipers to 4 piston on a 2023 110 S? Has anyone else completed this upgrade? Dealership would not help. Thank you in advance for your help.
Yes. If you're on 20" wheels, it will be fine. On P400s (which come with the four-pistons), 18" wheels will not clear the larger rear calipers unless you grind them down or swap them out with a smaller caliper. Hence why the 19" wheel is the smallest wheel on the P400. V8s have even larger brakes and won't clear anything less than a 20" wheel.
