Carrying 4 bicycles
Old Dec 5, 2021 | 11:58 AM
daviddarmanin's Avatar
4th Gear
Originally Posted by inater
One other thing, because of the rear tire on the door depending on the rack you cant collapse it up without an extender. I wanted to be able to access the back when camping etc so I went with the swing away which allowed access to the back and acted as an extender to allow for clearance of the tire when folding the rack up.
Hope this helps.
That looks awesome! Will check them out – wondering how many bikes they can carry.
Originally Posted by gts944
Road or mountain? If mountain and looking for a large number of bikes, consider a North Shore style rack which holds them vertically. Would still need a hitch extender or pivot.
Mountain... and this looks super! Is there a way to open the back door with this in place? If yes this would be the winner for me.
Old Dec 5, 2021 | 12:37 PM
gts944's Avatar
You'd also need a pivoting hitch adapter. Kuat Pivot for example, but there's several other companies making them too.
Old Dec 5, 2021 | 03:57 PM
Muppetry's Avatar
Originally Posted by daviddarmanin
That looks awesome! Thank you
Can you still open the back door with the bicycle mounted? If not how do you work around it?
Not really with bikes on the rack, even if you drop the rack down. You could try a swing-away style mounting arm, and I do use one of those (RakAttach) with my 1UP rack, but pivoting the 90 lbs of extended Thule rack plus four bikes on it is going to put a lot of strain on that system. The RakAttach is rated to carry 275 lbs though, so I guess it should work.
Old Dec 6, 2021 | 12:18 AM
GavinC's Avatar
I didn't bother with a pivot. I have no need for one as I only put bikes on when headed to a biking spot and then back home.
If I was buying anew I'd get the 1UP 4 bike rack and Kuat HiLo extender that I already have.
Old Dec 6, 2021 | 05:12 PM
Tartan's Avatar
I’m a long time 1up owner and fan, but I would actually go with a vertical hitch rack if I wanted to carry four bikes. The 1up is fantastic, but I dont like to carry any more than three bikes on it because it ends up sticking out too far. The kuat is even worse. I would go for one of these for four or more. https://www.velocirax.com
ATXdefender
Mar 2, 2023 04:15 PM
MrBreeze
Feb 9, 2022 05:09 PM
Paul64
Jul 30, 2007 09:38 PM
SSped
Jul 23, 2006 11:54 AM
