Defender v8 coolant odor on startup
Hi friends
i have a 2023.5 dv8 with 14k miles on it. More recently, when i start the car for the first 5-10 min i get a moderate coolant odor in the cabin that fades as i drive to an occasional whiff. No warning lights or low coolant levels and no visible leaks . Took it to my local dealer and they claim no leaks, normal pressure tests, and can’t perceive any smells.. but I’m obviously not making it up and I don’t think my dealer was that thorough. Wanted to see if anyone else had this problem and if so what the resolution was.
Hi friends
Dealing with it as we speak. As I said in my thread about this issue... Its more than likely your heater core if you're smelling it in the interior. Tell em' to do the pressure test with the heat ON. That said, dpending on how bad the leak, it may not register much on the pressure test. Mine defintiely failed the test, they didn't even try to feed me any mess. Plus the maple syrup smell was strong enough for even my kid to notice it...
Heatercore on back order. Trucks been sitting at the dealer for 2 weeks now. They have no idea when the part will come in. Could be a week. Could be 6 months. Opened a case with JLR and no response from them, and the dealer does nothing other than checks to see the status. which states "backorder no eta")
I just got my car back from the dealer, and no coolant leaks were found. They indicated that it could be burn off as this is the first time I'm using the heater since getting the car. Don't know if that is true or just BS they are feeding me. They did replace the cabin air filter as well.
funny cause i’m experiencing the same. only when my heater is on and my kids notice it also. it does go away after 5-10 minutes.
for back ordered parts, going through a similar issue with a so called back ordered part for months i was able to find the part at a neighboring dealership the same day.
i can tell you they don’t look very hard. i would not accept their response with no timeline
