Defender V8 Stock Exhaust Question
Old Oct 26, 2025 | 10:08 PM
  #21
DEFENDER P525's Avatar
4th Gear
Originally Posted by Skyfall
Oh so it’s part of dynamic, do you have to have it in dynamic drive mode to be able to control the valves?
Do you happen to recall the number or name of which CCF was added to obtain that icon?
I have dynamic mode enabled in mine, but would need to go in and find out if it’s available in my settings or not to even enable.
IID GAP TOOL G4:
MultiCAN-748 Active Exhaust Map - Installed
MultiCAN-688 ExhaustExhaus- Dual exhaust if you have a V8
MultiCAN-675 ActiveExhaustButton Type - Select Soft
Side note: I updated the Gap Tool G4 and my SV Dynamic-i screen / Active Exhaust Button changed form SV to the OCTA Diamond screen / Active Exhaust Button.
Honestly, I like the SV Dynamic-i screen better. Especially since my Defender is not a OCTA. I also find the SV Logo "Aesthetically Pleasing."
Old Oct 27, 2025 | 01:56 PM
  #22
Defend1's Avatar
You can also just unplug the valves. I tried this, but there was more drone sub 2500 RPMs than I would've liked.
Old Oct 28, 2025 | 09:47 AM
  #23
BD1's Avatar
BD1
I did the same and then plug them back. Didn't like the drone.
I like the software option and will give this a try.
Old Oct 29, 2025 | 11:38 AM
  #24
Defend1's Avatar
I would think that this would produce the same result – you’re just doing it via coding instead of manually
Old Oct 29, 2025 | 09:48 PM
  #25
BD1's Avatar
BD1
With software it is much easier to turn on and off
Old Nov 2, 2025 | 06:53 PM
  #26
lawlence's Avatar
Can anyone confirm this question? I ended up installing an aftermarket module to control my flaps via the ESP button, but that button isn't always the most responsive (you have to toggle ESP on and off, and there's kind of a minimum dwell time before it toggles).
Old Nov 3, 2025 | 04:48 PM
  #27
Waldramos's Avatar
This is the Active Exhaust icon installed and functional. I used the IID Gap Tool G4. In this photo the valves are closed
In this photo the valves are opened and the stock exhaust with a resonator delete - X-Pipe replaced it snaps crackles and pops!!! No need for an aftermarket cat back system.
In this photo the valves are opened and the stock exhaust with a resonator delete - X-Pipe replaced it snaps crackles and pops!!! No need for an aftermarket cat back system.[/QUOTE]
This is on a V8? OR P400/?
Thanks a lot.
Old Nov 3, 2025 | 04:51 PM
  #28
Waldramos's Avatar
would you show us where its this plug that you talking about?
thanks
Old Nov 3, 2025 | 08:48 PM
  #29
Defend1's Avatar
thanks
there’s two plugs for the actuators - one on each side of the muffler.
Old Nov 8, 2025 | 04:55 PM
  #30
Dillchambers's Avatar
8th Gear
how did you get this to display ? I have the settings enabled and the i dynamic config screen but can not find this anywhere
