Is delivery of the 110 with p300 4 cylinder turbo ending?
Old 02-04-2022, 11:22 AM
NoGaBiker's Avatar
Received 1,402 Likes on 689 Posts
Originally Posted by Bigwood
I don't believe that these will ever be collectable. If the new defender proves to be a winner long term, I suspect that they will keep making them as fast as they can. The only reason the old ones are popular is the limited amount that are available in the US.
I tend to agree. Possible exception being that supply chain issues don't get resolved sufficiently to produce large numbers of the L663 before time for the next gen EV-based version is launched, ensuring a limited supply for all-time.
  #42
Old 02-04-2022, 11:24 AM
Yulongtd6's Avatar
Agree as well, the only potential ones with sustained value will be V8 if they switch to electric.
  #43
Old 02-04-2022, 04:25 PM
Pdflrd's Avatar
Lets not forget that as recently as 2005-2009 the mighty Range Rover was powered by a naturally aspirated 4.4-litre Jaguar AJ-V8 engine producing 300 hp (224 kW) and 425 N⋅m (313 lb⋅ft) and the engine weighs 441lbs. This is almost identical to the P300 2.0 Turbo 4 other than engine weight which is also probably double the weight and 55% larger displacement. (I can't find the weight of the 2.0L engine anywhere) The horsepower wars with bigger numbers doesn't translate to real driving needs on a regular daily basis. I don't think of the Defender as a 0-60 rocket, I drive it as a quick tank. The one thing that is the most dramatic aspect of driving all Defenders are the commanding presence and view. You are high up but not tippy and have great visibility out the windows other the back but the clearsight mirror does a great job of fixing that. Love this SUV.
gb_junkie (02-06-2022)
  #44
Old 02-06-2022, 08:28 AM
gb_junkie's Avatar
this is spot on. coming from an L320 range rover sport with a 4.4l AJ V8, my p300 defender 110 feels a lot peppier than the numbers on paper suggest. i believe the 0-60 time for the range rover sport was 8.7 seconds, the p300 defender does it right under 8 seconds. the defender being ~700 pounds lighter than the L320 helps with the peppier feeling too.
  #45
Old 02-06-2022, 08:37 AM
Defendit..'s Avatar
Does it right under 8 seconds ? Maybe in normal D mode
Mine D90 does it under 7 seconds in S (sports) mode
  #46
Old 02-06-2022, 08:52 AM
gb_junkie's Avatar
I'm seeing 0-60 numbers all over the place for the P300's (ranging from 7.0-8.1 seconds) - even on Land Rover USA's site - it says:
which seems like a misprint, figure the 90 would have the edge performance-wise. my butt-o-meter thinks 7's is about right.
Reyesahr
01-06-2016 01:49 AM
rupert
Defender
07-16-2015 12:45 PM
RKW
02-02-2014 08:19 AM
drdeadchef
06-10-2012 10:10 AM
Quick Reply: Is delivery of the 110 with p300 4 cylinder turbo ending?
