Drivers side headlight washer leaking
Old Jul 18, 2021 | 08:02 PM
Ahparke's Avatar
Default Drivers side headlight washer leaking
Went to test my 2022 defender today before taking delivery.. Everything looked outstanding other than it seemed the front drivers side headlight washer jet was leaking.
I know that this is a known issue I have seen on the FB groups but couldn’t find a thread for it here. Does anyone know if there is a known fix/SSM for this issue?
… or is something leaking on day 1 just to be expected
Old May 30, 2022 | 10:29 AM
BritishGreen's Avatar
Did you figure this out? I picked up new Defender two days ago and it is doing the exact same thing.
Old Feb 10, 2023 | 09:59 PM
Nati's Avatar
Still an issue for cars built in December 22 apparently.
Old Feb 10, 2023 | 11:06 PM
Nuckle's Avatar
How do you test this? I don’t know that o have ever used mine.
Old Feb 11, 2023 | 05:17 AM
EasternShoreDefender's Avatar
The headlight washer is activated with the windshield washer.
Old Apr 3, 2023 | 10:17 AM
fsts2k's Avatar
Originally Posted by drcoop
My '22 has leaked since the start, causing this dull staining on the plastic headlight trim. Have lived with it, but if this is common and LR acknowledges it, I would like to have it fixed.
Did you happen to identify a solution to this and figure out how to remove the stain from the headlight surround? I have the same issue.
Old Jun 1, 2023 | 02:18 PM
FERRYMACHINE's Avatar
same here. big stain on my brand new defender.
how do i remove it?
Old Aug 10, 2023 | 10:48 AM
Myron's Avatar
I took delivery of my 110S two weeks ago and noticed the weeping driver's side (L) washer jet yesterday. As others have noted, it leaves behind an ugly stain on the glossy plastic trim piece. I rubbed it with my thumb and was able to buff it out, but the weeping continues so obviously it will return.
I will check in with my dealer and let everyone know what they say.
Myron
Old Aug 13, 2023 | 05:59 AM
brandx's Avatar
My 23.5MY X-dynamic has BOTH headlight nozzles leaking, identified within 1 week of delivery. Dealer collected vehicle from my house and took into shop for review and acknowledged the seals were defective. Mine too had awful staining from the fluid (black body so it showed up more). I had the shop empty the reservoir and clean up the paintwork. They actually did a great job at cleaning it up but I was without washer fluid until this can be fixed. Parts were on backorder and now 8 weeks into ownership only JUST showed up. Hopefully will get in within the week to install and put this behind us.
Old Aug 13, 2023 | 10:28 AM
chpsk8's Avatar
My 23.5 delivered 7 days ago has the same issue. Walked by last night and wondered why there was white stuff all around the drivers headlight washer. I've never used the windscreen washers, haven't had a need so this is just sitting there leaking like that.
