Extended Fender Flares US Spec
#31
Did you also just wrap up the connectors and tuck them away? anything special to keep em' safe/away fromt he elements since they will remain 'hot' when the lights are on?
#32
i wrapped them in a plastic bag and taped them really well then put another bag on top of them and then tapped them really well. i doubt water will get in unless submerged
#33
Does anyone know if the bonding adhesive used to attach the arch extensions is permanent? Will it cause paint damage if arch extensions were to be removed later? I purchased at certified preowned defender that the previous owner added these rock chip guards. I don’t mind them, but would have to remove them in order to add the arch extensions discussed here. I believe they might use the same bonding adhesive and obviously don’t want to cause paint damage if I pry them off. Thanks for any knowledge!
#34
