Extreme wind noise : 2021 defender 110
Old Mar 25, 2022 | 07:03 PM
Eb21's Avatar
Originally Posted by Muppetry
An obvious question - is the window fully closed?
yes...rolled it up and down probably 10x hoping something would change .
checked the door molding ...window felt etc ...all looks new.
Have an appointment with the dealership on April 4th ...if they can't resolve it ...PUTTING IT UP FOR SALE IMMEDIATELY
Old Mar 27, 2022 | 11:44 AM
Eb21's Avatar
I believe I found the issue. Appears the window is loose as well as the door molding.
Is this the pillar problem others have discussed?
I made a video but I'm unsure if it will upload...androids are not the best at sharing videos etc.
https://photos.google.com/share/AF1Q...NJUmVWNE90dDVB
Old Mar 27, 2022 | 02:51 PM
Norsk's Avatar
Wow, that’s horrible. Bet it sounds like a V-1 rocket behind you. Should be a relatively simple fix for the dealer.
Old Mar 27, 2022 | 04:18 PM
Eb21's Avatar
Originally Posted by Norsk
Wow, that’s horible. Bet it sounds like a V-1 rocket behind you. Should be a relatively simple fix for the dealer.
I am somewhat relieved to have discovered it ..was driving me insane.
Hopefully it can be fixed easily.
Old Mar 28, 2022 | 04:16 PM
Muppetry's Avatar
At least you found it. When I asked if the window was closed I was imagining it leaking air at the top, not flapping in the wind at the bottom.
Old Mar 28, 2022 | 04:28 PM
Eb21's Avatar
QUOTEThe loose window is definitely the problem. Yesterday, I duct taped the frame of the window and today zero noise..AMEN !
Old May 10, 2022 | 02:42 PM
bham29's Avatar
Default Resolution.
Can you tell me how this was resolved? I had zero noise for about 4000M and recently the same exact noise you describe appeared, upon reviewing my car and the photo attached this must be the issue as my rig has the same, When i push on the window from the inside i can make it gap quite far with minimal pressure.
please let me know how this was resolved as the dealer is booked for months with the service appointments.
I just purchased a 2021 110 SE p400 with 7700 mi on it.
Today ,was the fourth day that I've had it on the interstate and the noise was unbearable.
A few days ago, I had a constant wind noise in my ear coming from the passenger driver side window. If I turn the radio volume up to about 30 it drowned it out but if I turn the volume down and tried to make a phone call ,all I could hear was the wind in my ear as if I was in a jeep with no top on it. Today ,the same noise except for now there's a whistling coming from the window as well. I contacted the dealer and I was advised they could see me in two weeks .. I am hoping some of you guys have a solution to this.
Thk you
UPDATE 3/27/22
Old May 15, 2022 | 09:42 AM
Eb21's Avatar
According to my service advisor, this is becoming a known issue. The truck was in the shop for a week and they replaced the window and reglued the molding. I picked it up and on the drive home ..>SAME NOISE! Needless to say, I was livid! I took it back to LR and they replaced the window again and installed new molding. A month later and no issues. SA told me that the window is on backorder now, so this is a significant issue now.
FendyinOz
Sights N Sounds
Jun 15, 2022 02:48 AM
2020Defender1stEdition
Sep 24, 2021 02:36 PM
Tonyva
Apr 26, 2021 08:26 AM
Michael Jeffery
Feb 20, 2021 09:57 AM
karlmphysics
Mar 18, 2013 08:42 PM
