Factory air compressor accessory question…
Old Feb 22, 2024 | 03:59 PM
roverzfan's Avatar
Default Factory air compressor accessory question…
So I bought my D90 used.
It came with the air compressor in the back but didn’t have the air hose. Looked like a standard 1/4 inch nipple so I figured I’d just use the hose from my compact compressor I keep in the garage. Yesterday when I went to test it the nipple looks like a 1/4 inch but you can’t press the quick connect on far enough to catch. There is some kind of rubber bushing flush with the case. Is there some kind of custom quick connect used here? Or is that rubber bushing not supposed to be there?
I’ve attached some pics to help clarify.
This shows the end fitting looks just alike
If you compare the fitting in the first photo you see it has that 1/2 inch or so where the quick coupler would slide over. Not so on this fitting.
Your guidance would be much appreciated.
Old Feb 22, 2024 | 05:05 PM
Defendit..'s Avatar
Do you have a euro coupler ?
https://www.pneuparts.com/en/subcate...couplings-euro
Old Feb 22, 2024 | 05:45 PM
tbrown's Avatar
Mine doesn't seem to have that ring.
Old Feb 23, 2024 | 08:08 AM
roverzfan's Avatar
Thanks for the input and the additional pics showing the compressor without the bushing. Much appreciated.
Old Feb 25, 2024 | 07:56 PM
vinceleo's Avatar
I found a box under the rear cover of my cargo area with the air compressor hose however I don't have the factory air compressor. So, nosing around Lucky 8's website, I saw their strut tower air compressor kit... I open the hood and there it is installed and tucked nicely away - apparently the prior owner added the kit, and I had no clue. A pleasant surprise to say the least.
Strut Tower Air Compressor Kit - With or without Compressor – Lucky8 Off Road (lucky8llc.com)
I also have the Lucky 8 rock sliders, giant upper cargo light and rear door table. Wonder if I found everything?
JMF20
Dec 27, 2023 04:17 PM
nedefender
Nov 19, 2023 06:52 AM
inater
Jun 29, 2023 12:57 PM
sayvillerx
May 7, 2021 06:40 AM
TheMgmt
May 21, 2019 02:39 PM
