Fitting a roof tent onto the factory defender roof cross bars?
Old Feb 14, 2021 | 06:48 PM
karlos73's Avatar
Default Fitting a roof tent onto the factory defender roof cross bars?
Does anyone know if I can fit an I-Kamper or Roof nest Condor XL (Still deciding which to buy) roof tent onto the factory defender roof cross bars?
I take delivery of the car with the factory cross bars and wanted to check?
Old Feb 17, 2021 | 12:20 AM
spikemd's Avatar
It should fit. The load rating is pretty high on the bars.
Old Feb 20, 2021 | 09:10 AM
sblvro's Avatar
unless only one person is going to sleep in it, that is past the load rating?
Old Feb 20, 2021 | 11:55 AM
ILikeTacos's Avatar
That would be passed the dynamic load rating, not the static.
Old Feb 20, 2021 | 08:31 PM
FzyPChz's Avatar
What’s the static weight rating?
Old Feb 21, 2021 | 06:57 AM
carlmuck's Avatar
300 kg/661 lbs
https://www.landroverusa.com/Images/...293-767787.pdf
Old Feb 21, 2021 | 09:22 AM
sblvro's Avatar
Originally Posted by carlmuck
what is the 176 for?
Old Feb 21, 2021 | 11:41 AM
carlmuck's Avatar
As the document says. 176 lbs is the dynamic load for non-all-terrain tires. 220 for AT tires.
Old Feb 21, 2021 | 03:29 PM
Tartan's Avatar
You’re mixing up roof load rating and the rating for the crossbars. Crossbars can only take 207 lbs dynamic. Roof is rated higher, but you have to go with the lower bar rating.
Old Feb 21, 2021 | 03:46 PM
carlmuck's Avatar
So I'm not sure how to translate these number, other than to say that Land Rover has a bunch of numbers they throw around.
My earlier post quoted a doc that says max dynamic load is 260 lb with AT tires. This post has the expedition rack capable of 291 lbs (dynamic) (https://www.landroverusa.com/vehicle...cessories.html).
Is there a crossbar static rating?
