Flat batter followed by SOS warning
Old Jan 9, 2025 | 10:09 AM
wlindsey@gmail.com's Avatar
Default Flat batter followed by SOS warning
So, I managed to leave something plugged into the defender and the result was that I ran the battery down. I was able to “jump start” the vehicle and eventually all the electronic warnings sorted themselves out. It’s back to normal now, except for an “SOS Warning”. From research, that indicates I need to replace the SOS battery - but my question is … is it just coincidence that the SOS battery now needs to be replaced? If I do nothing, will it recharge after a while?
Old Jan 9, 2025 | 11:16 AM
wcc18999's Avatar
Probably just coincidence. How old is your Defender?
Old Jan 9, 2025 | 04:06 PM
2020. There’s pretty good instruction on this site about changing it. I just didn’t want to go through it if there was a chance it would recharge from normal driving.
Old Jan 9, 2025 | 04:22 PM
Fifth Horseman's Avatar
With the vehicle battery disconnected or completely discharged the telematics unit internal battery will be powering the unit, so no coincidence.
If you can check for error codes you will most likely show a U2109 fault showing telematics battery discharged. Workshop manual suggests you need a minimum of 60 minutes engine running time to recharge the telematics battery followed by clearing the DTC. If this fails then a replacement telematics battery is likely required.
POPTOPP
Jan 12, 2025 03:45 PM
Hovdebo
Nov 19, 2024 06:11 PM
GrouseK9
Aug 23, 2024 06:15 PM
Muppetry
Jan 14, 2024 01:32 PM
mopadzi
Jul 31, 2023 02:08 AM
