Front rubber LR floor mats suck
#51
This is what I got…originally so I could solder without needing to be plugged in.
I only used the hot knife part to cut 550 cord and nylon straps because it would cut and seal at the same time. Glad it worked for this mod.
They offer a “pencil” style version as well. I chose the one above because with the plastic base that comes in the kit, it will stand on its own. It also holds a bit more fuel.
MattF (01-19-2023)
#52
One thing I have noted about mine is that I do have a bit water/mositure build up between the mat and the floor, but I don't tend to drag water/snow into the car with me in this dry winter. I wonder if this moisture is condensing in-between due to humidty getting trapped rather than leaking through those holes. Just a thought.
