Full Respray D90 in progress
Old Dec 13, 2022 | 10:26 AM
  #31
Defendit..'s Avatar
( double post - deleted)
Spraying other side, fender replaced, front rebuild
Old Dec 13, 2022 | 11:39 AM
  #32
clubguy's Avatar
Originally Posted by Defendit..
Thx. Done the winch in January, winchtray, winch, relocated relay and highbeams can be found in the Lucky8 winch tread https://landroverforums.com/forum/20...e3/#post808085
Can you do mine?
Old Dec 14, 2022 | 05:37 PM
  #33
Defendit..'s Avatar
Driver side finished today with all the cladding - many new clips used
Front back on, everything connected,.
Front finished, fairlead, powered the vehicle up for the first time after dismantling, winchrope back on tension
Tomorrow cladding passenger side and some work left on the rear.
Old Dec 14, 2022 | 06:24 PM
  #34
clubguy's Avatar
Love that winch setup and the color.
Old Dec 15, 2022 | 08:18 AM
  #35
Defendit..'s Avatar
Today's first out.
Got a problem with the electronic lock of the tailgate, did make a bypass Yesterday for an extra release switch. Everything connected it did click.
Tailgate accidentally closed before proper testing, doorhandle switch does nothing now...
My 90 is converted to an Hardtop/ Commercial with full bulkhead, no way to get in.
So I have to find out who can help me with the powerful modification to enable the Tailgate switch on our FOB.. CCF ,see below
Any advice is greatly appreciated ( before I make a manhole in the Bulkhead )
Old Dec 15, 2022 | 10:33 AM
  #36
Jarrodrex's Avatar
Wow that’s a great color. Well worth the work. If that was a stock color I would have 100% gone with it. The stock greens don’t do it for me. This one just pops.
Old Dec 16, 2022 | 04:15 AM
  #37
Defendit..'s Avatar
Thanks !
Anyone out there to help with the tailgate lock problem ??
Old Dec 16, 2022 | 02:38 PM
  #38
Jarrodrex's Avatar
Start with the easy troubleshooting. Is the battery connected? Looks like you had a lot pulled apart. Make sure you have power. Check all the connections you can get to unplug re-plug in make sure they are seated right. After that yeah you might have to cut into the bulkhead or drill a hole or two to see what’s going on. If you can try to unplug the extra harness and take it back to original.
Old Dec 19, 2022 | 11:18 AM
  #39
Defendit..'s Avatar
Managed to get the bulkhead at the underside loose, enough to get in.
This involved to remove the front seats and the middle console first.
Repaired my bypass at the wireloom of the Tailgate release switch. So everything back to original.
Sparetire mount reinstalled, sparetire back on.
Everthing reinstalled in the cabin,front..
Mud table back on.
Old Dec 19, 2022 | 03:50 PM
  #40
ThunderBob's Avatar
Glad you were able to able to get back in with out any damage. You must have the patience of a Saint. I would have been bouncing off the walls.
Excellent work on an awesome project!
