A good way to fix the sticky side ladder?
Old Jun 23, 2023 | 03:45 PM
Anuo's Avatar
Lightbulb A good way to fix the sticky side ladder?
It became so sticky that the entire car is shaking every time I tried to use the ladder. I didn't notice any rusting and have tried spry WD-40 into the latching mechanism, didn't seem to help. It seems to be a common issue, not sure if any of you have a good solution. Many thanks!
Old Jun 23, 2023 | 08:25 PM
tbrown's Avatar
Haven't dug into it yet. But I've got the same.
Was thinking of swapping it out for the Proud Rhino rear ladder. Although I got their (Lucky8) recovery board mounts and all the hardware for mounting is crap and all wrong. So I am starting to question myself.
Old Jun 24, 2023 | 07:28 AM
MattF's Avatar
I'm unclear what "sticky" refers to in this specific case but on the chance you're having an issue with the ladder releasing when you pull the release handle you might want to look at the actual latching mechanism. The "U" shaped latch that the hook hooks into can be slightly out of alignment. It can be gently bent back into alignment such that the hook part of the latching mechanism can fully release. I had this issue with mine.
Old Jun 24, 2023 | 08:19 AM
sacharama's Avatar
Aren't your vehicle still under warranty?
Unless the ladder has been damaged, I can see it can be considered as a warranty fix?
Old Jun 26, 2023 | 11:51 AM
Anuo's Avatar
No, it's out of warranty by milage.
Old Jun 26, 2023 | 06:27 PM
wcc18999's Avatar
There is a certain way to pull the ladder towards you when unlatching and then you can unfold and use the ladder. I had trouble with mine when I installed first until the time I learned how to pull at yourself first and then unfold. Quirky for sure but just give it a try. That is if your issue is related to unlatching and unfolding the ladder.
Old Jun 26, 2023 | 06:36 PM
tbrown's Avatar
I think this is it with mine.
Only opened it a couple of times and was like "WTF, this is not working". Over the weekend I used it a bit more and towards the end figured out you need to pull on both ledges ("top" and unfolded "bottom") for it to come down. It's still sticky and requires more force than I would have thought. But I am going to attack it with some grease and WD-40 to see if that helps.
Old Mar 20, 2024 | 07:23 PM
cgardnerma's Avatar
I made my sticker ladder much smoother. I decided to undo for bolt to remove the ladder from the frame to see what's going on. It turns out there are for stainless steel spring loaded bearings that snap into the aluminum groove in the ladder. Two on each side, top and bottom. That's why you have to pull on the top and the bottom to get the ladder out. They are also VERY STIFF. So stiff I can not depress the ball with my fingers, but only with pliers. They are on a very strong spring to keep it in place. The spring is so strong the stainless bearing is actually carving a groove in the aluminum. When I had it apart I put some thick grease on all four bearings. Hopefully it stays in place, but the ladder is much easier to deploy now. See pics below.
JGIB627
Jun 6, 2021 05:50 PM
DISCOFETA
Apr 3, 2020 11:09 PM
LR03NJ
Sep 15, 2017 03:24 PM
sdsilvere38
Oct 1, 2008 12:37 AM
