Hitch
Old Jul 25, 2025 | 10:01 PM
jamesembry's Avatar
Default Hitch
Unfortunately my Defender didn't come with a hitch. Is there a good solution other than spending 5K at the dealership?
Old Jul 26, 2025 | 05:12 AM
Defendit..'s Avatar
Buy your parts, new or used. DIY or Indy. 5 hours work ex.CCF work ( 20 minutes)
Towbar VPLET0273 NAS Towbar Original.
VPLYT0295 Towbar module.
LR146117. Wiring loom. ( This could be a different part number, check before ! )
Get yourself a GAP IIDTOOL BT v4 and program your CCF
CCF Towbar
EUCD-076 Tow bar With Trailer Tow Attachment
MultiCAN-504 Trailer Light Mod Fitted
MultiCAN-579 Tow Assist Tow Assist 2
MultiCAN-635 Towing Not supported
MultiCAN-678 Hitch Assist Towbar 5 Seat NAS Towbar
MultiCAN-696 ATCM TA2 Switch Tow Assist 2 feature selection switch not fitted
MultiCAN-793 TA2 Input Control HVAC rotary
MultiCAN-795 TA2 Select In FCPB Rotary used for selection within touch screen
You can modify the lower skidplate.
Old Jul 26, 2025 | 11:03 AM
wcc18999's Avatar
Check your local U-Haul location for hitch installs.
Old Jul 26, 2025 | 11:38 AM
Hieu Nguyen's Avatar
U-Haul will install without programing? are there any issue if no programing?
Old Jul 26, 2025 | 02:15 PM
wcc18999's Avatar
You can always have it programmed by the dealer if you are planning to hook up the electrical wiring for the hitch. If you just want the hitch for the purpose or putting a bike rack on it, there is no need for electrical wiring.
Old Jul 26, 2025 | 03:17 PM
DonMitsu's Avatar
I would use a factory hitch. It replaces the rear aluminum bumper core with a steel bumper core. An aftermarket hitch will not be as well-built. That being said, I installed mine on a Saturday. If you're somewhat mechanically inclined, do your own install.
Old Sep 4, 2025 | 08:49 AM
SmokeytheBear's Avatar
6th Gear
Default DYI is the way to go
Agree with all. As long as you have some mechanical skills and some automative tools, it’s really not that hard to do. Both Lucky 8 Off-road and PowerfulUK have some great YouTube videos on step by step.
you can procure the kit in US from various sources, but I got the kit from Lucky 8 which came with Land Rover tow hitch, factory wiring loom, and factory computer.
Make sure you get the GAP ID Tool V4 if you don’t already have. This in itself is a must for any Defender owner.
i did the install by myself, but would have been easier if I had a helper. Lastly I bought a cordless ratchet which helped me a ton. Got one on sale at big box store for $80.00.Good luck!
Old Sep 4, 2025 | 03:30 PM
nashvegas's Avatar
Hmm... I would never let any U-Haul tech touch my Defender. Either the physical part or the electrical part. Asking for problems. Ever.
Also the hitches they install are rubbish compared to the stout factory stuff. This is an aluminum body / chassis. Different than days of old. Not a bolt on crossbar and cut a hole in the bumper thing.
Unless it’s just for a bike rack or something. For a trailer .. factory all the way.
TIto
May 13, 2025 12:01 PM
Submariner2009
Jan 31, 2024 07:38 PM
Auch
Nov 30, 2023 07:47 AM
hailyourself
LR4
Aug 31, 2022 08:04 PM
Kalel
Sep 29, 2011 02:22 PM
