How do I get the Brake hold feature to stay turned off?
Old Aug 18, 2024 | 10:47 AM
cc1999's Avatar
Originally Posted by pjeski
You are correct, I was remembering wrong. I've had mine disabled for so long I couldn't remember. But the setting I posted above does disable demand hold as well. Whoever thought demand hold was a good idea probably rides a bus to work.
I was thinking the same thing. Lol
‘I can’t see any benefit of that hold feature, especially on an automatic transmission vehicle. Maybe a hill start on a manual transmission vehicle.
I really appreciate the info, seems the GAP tool I ordered, really is a must have device for LR owners. It’s needed just to shut off some of this silly stuff. Lol
Old Aug 19, 2024 | 12:36 PM
Iceman153's Avatar
I personally love the on demand auto hold, once you know it's there I've never accidentally activated it. I only use it at traffic lights, even if not on a hill I find the car takes off more smoothly specially if you are giving it a bit more pedal. the auto setting is a parking nightmare however.
Old Aug 19, 2024 | 01:54 PM
cc1999's Avatar
Originally Posted by Iceman153
I personally love the on-demand auto hold, once you know it's there, I've never accidentally activated it. I only use it at traffic lights, even if not on a hill I find the car takes off more smoothly specially if you are giving it a bit more pedal. the auto setting is a parking nightmare however.
I am sure it is something I could get use to at some point. Problem I have is owning several vehicles and this being the only one that does this brake hold thing.
It makes my starts and stops from a stop light a lot more jerky whenever that brake hold function is activated.
I think for me after 40+ years of driving and nothing really ever having this Brake Hold feature, it would just be easier for me to shut it off entirely.
That way the Defender operates more like all my other vehicles.
If that makes any sense.
Old Aug 19, 2024 | 03:09 PM
Iceman153's Avatar
Yeah of course, it's totally preference, I do sometimes find myself doing the pedal jab in my other car. Was just trying to point out that it may actually have benefits if you have the patience to learn how to control it. With how much hate the feature gets on this forum I always wonder if the strength of the jab you have to give differs from car to car. In mine it won't activate without a sharp purposeful jab on the brake pedal after coming to a full stop. It kind of behaves/feels like you are activating an old foot pedal parking brake with a shorter travel. I think that's the motion they were trying to emulate with this feature. Also note there is a visual "HOLD" indicator on the dash that you can use to be sure it's active before letting off the pedal.
The fact that the "auto" mode is enabled by default is stupid and gives a bad first impression, it's terrible, and almost caused me to hit my garage when I first brought the car home trying to park it. You can't creep forward with it active so I usually only use it when I'm first in line, or I know there will be a bit of a wait before moving. If it randomly turned on for me like yours does I'd want it gone too.
Old Aug 19, 2024 | 06:47 PM
WTFChuck's Avatar
Iceman153: Apparently this feature stirs up quite a bit of angst, while others enjoy it. I also use it for certain purposes and find it helpful in those circumstances, it becomes second nature and I’ve never activated it unless I choose to. It’s much easier to use it judiciously than it is to bemoan its existence. For those that can’t live with it, that’s where the GAP tool comes in. The GAP tool maker is smiling all the way to the bank.
Old Aug 19, 2024 | 06:51 PM
pinion's Avatar
My hate for this feature comes from hitching my trailer. It incessantly activates in and off as I carefully back in to line up when hitching or positioning the trailer. It’s possible that it is because I am on a slight grade and it think it is helping but it really isn’t. I use low range to ease the load on things while backing up and even with slight steady throttle application you can hear the parking brakes cycling on and off while creeping into position. Disabling this will be the very first thing I do when my GAP tool arrives. Well perhaps after I finish my oil change and service indicator reset.
Old Aug 19, 2024 | 06:54 PM
GavinC's Avatar
Don't need gap to do that, although it's simple to reset it either way.
With or without tool.
Lo range for tiny movements hooking up a trailer. Genius. Thank you for the tip.
Old Aug 19, 2024 | 07:46 PM
Iceman153's Avatar
I've hooked up to plenty of trailers without it coming on and off, I always feel like I'm in full control of when the hold activates. You sure you don't have the "auto" hold enabled? If not, this has to be either a braking technique difference, or maybe some vehicles are more sensitive? But if you just rest your foot on the pedal when stopped it shouldn't be turning on.
Old Aug 19, 2024 | 07:53 PM
pinion's Avatar
It makes sense that it shouldn’t be and yet it does.
I have the auto hold in my quick settings and I have tried both with the circle filled/unfilled since it seems to be applying regardless of which way it is set.
The only way I can prevent it from coming on is to continuously apply and ever so slightly feather the throttle (low range, reverse, slight grade). If I don’t it immediately applies which makes me think it is some sort of grade sensitive holding feature combined with brake hold.
I am aware of what pressure is normally required to activate a hold at a light and I am no where near that level at any point.
For overall context I am not hitching up that often but enough that I will disable this when given the chance.
Old Aug 19, 2024 | 09:07 PM
Iceman153's Avatar
yeah that doesn't sound right, it almost sounds like your auto hold setting isn't having any effect if its always applying like that. Pretty certain an incline has no impact on it.
