Initial throttle in the morning
Old Oct 28, 2022 | 02:41 PM
sany84's Avatar
Default Initial throttle in the morning
experts, I got a new defender and in the mornings when i start it seems to run at high rpm as soon as engine starts and when i start driving its normal. and subsequently during the day i dont see this. Is this normal for defender? I live in north east and not sure if temperature has anything to do with this?
Old Oct 28, 2022 | 02:44 PM
EasternShoreDefender's Avatar
How high? I've had a few cars over the years do this. There's a more technical explanation out there but i believe it's part of the warming up process and getting the engine to temperature.
Old Oct 28, 2022 | 03:25 PM
MattF's Avatar
Mine does that as do all my cars. it's primary purpose as I understand it is to warm the cats quickly for emissions.
Old Oct 28, 2022 | 03:27 PM
POPTOPP's Avatar
Whenever I start a cold engine, I run at about 1500+ rpm for about 30 seconds. Then it drops to normal idle and stays that way.
Old Oct 28, 2022 | 03:47 PM
Drednot's Avatar
Mine does the same thing until I put her in gear. Normal for the reasons given above.
Old Oct 28, 2022 | 03:53 PM
sany84's Avatar
Thank you all. Looks like a normal primer. I had many vehicles and none did this. So I got curious…
Old Oct 28, 2022 | 07:25 PM
Trekkie's Avatar
Far as I know every ICE car has done something like this forever. I just let it idle until it drops and then go. haven't timed it but I don't think it's always 30 seconds unless it's really cold overnight
Old Oct 28, 2022 | 07:31 PM
GavinC's Avatar
With the turbos in the P400, it sounds like she's about to head for low earth orbit when fired up.
I flipping love it.
Old Oct 28, 2022 | 09:40 PM
HAL9000's Avatar
8th Gear
That is the emissions system working. Engine idle speed is increased for the first 30-60 seconds of a cold start to heat up the catalytic converters to operating temperature and reduce emissions.
It goes back down after you start driving because driving puts load on the engine which heats up the cats, so higher idle and secondary air pump are no longer necessary. And you don't see it on subsequent trips because the cats don't have time to cool all the way down to ambiant temps between trips.
Loliwu
Aug 8, 2023 06:01 PM
amcarroll
Sep 25, 2022 02:43 PM
FendyinOz
Defender
Jul 1, 2022 04:55 PM
GrouseK9
Mar 30, 2022 09:02 AM
DCH12
Jan 11, 2022 05:53 PM
