Instrument Cluster Brightness
Old May 14, 2026 | 12:50 PM
L460_Rocks's Avatar
Default Instrument Cluster Brightness
I did a search here and didn't find much. The instrument cluster in my '26 110 V8 is too dim and keeps changing brightness on its own all the time, Is there any way to set it on the desired brightness and leave it there? The tiny dial button below the parking brake is already set to max brightness but the cluster goes very dim even on sunny days. I looked into pivi options, nothing. CCF edit somewhere, maybe?
Edit: In my '25 Range Rover the brightness is constant, it's perfect.
Old May 14, 2026 | 06:47 PM
Vadiable Paradox's Avatar
Incidentally, I found it by accident after 16 months of owning the vehicle.
Open the driver's door, look under the handbrake, there's an area with the icon, and the control in the middle - you might need to press it to pop it out, or, like in my case, it may be already out.
Old May 14, 2026 | 08:08 PM
L460_Rocks's Avatar
I did that already. Doesn't work. The cluster still dims to very low brightness apparently in a random manner. Maybe it has to do with the daylight hitting some sensor or not but I wish I could turn off this auto-brightness thing and just set it manually.
Old May 14, 2026 | 11:42 PM
isugoo's Avatar
I' gave up making it crisp and bright like other brand cars. I don't think there is any cure unfortunately.
Old May 15, 2026 | 12:16 AM
L460_Rocks's Avatar
That's not very encouraging....
Old May 15, 2026 | 04:36 AM
CincyRovers's Avatar
Unfortunately there isn’t anything you can do about it. I just learned to live with it constantly adjusting itself.
Old May 15, 2026 | 09:29 AM
H1Tad's Avatar
This is a very common complaint with the Defender - and has been for years. Seems JLR is unwilling to do the needful and make screen brightness something that we can actually define for ourselves in system settings.
It's especially bad on a rainy, cloudy day. I've had 7 eye surgeries that resulted in me having low-light vision loss and its dangerous for me to spend as much time staring at the instrument cluster as I do because JLR won't allow me to increase the brightness of it.
Old May 15, 2026 | 03:44 PM
L460_Rocks's Avatar
I agree, I have complained about this and some other quirks a while back when they sent me a survey. They had a feedback suggestion box, I almost wrote a book in there.
pepeysol
LR2
Jul 21, 2024 09:34 AM
jonathan pouesi
Oct 11, 2023 02:37 PM
04disco2va
May 7, 2021 06:21 PM
Wesley Cantrell
Oct 21, 2017 08:48 AM
