Insulation coming out from driver's footwell?
Old Dec 30, 2025 | 04:32 PM
FinisherCar's Avatar
8th Gear
Default Insulation coming out from driver's footwell?
I happened to be cleaning my floor mats and saw some insulation looking material poking out from the driver's footwell, above the brake pedal area. This normal? Never noticed this in any other car before
Tucked away
Tucked away
Pulled out
Pulled out
Old Dec 30, 2025 | 05:21 PM
nashvegas's Avatar
It’s underwear are showing!
Not a big problem. So I’ve had that panel off the car before when I installed my GMRS Radio. Basically, there is some sound attenuation insulation “glued” to the upper side of that lower dash panel. I am guessing what has happened is that it has come adrift.
I’d just push it back up there neatly which is probably all a dealer would do. I doubt they’d even replace that with a new part under warranty, but perhaps even if necessary.
I found this on ebay -- you can see here the insulation adhered to the upper side of the trim panel (with hot glue gun like material in a few spots) . This is the passenger side piece not drivers, but... same deal.
Hope that helps.
Old Dec 31, 2025 | 09:35 AM
8th Gear
Hope that helps.
Thanks! That's what I figured, glad to know what it is.
nashvegas
Mar 19, 2025 01:02 PM
switch
Range Rover Velar
Sep 22, 2023 03:45 PM
stsao
Dec 20, 2022 09:54 AM
kpl1228
Mar 11, 2012 03:03 PM
03discoman
May 7, 2010 06:28 PM
