Interior Finisher Trim Swap (Pics)
Old Feb 21, 2022 | 10:17 PM
NoGaBiker's Avatar
The wood ones (oak and walnut) are real wood. It’s veneer, like most furniture finishes and like practically every luxury car out there. But it’s attached to a plastic underlay for structural purposes.
For 10 years I had a 1968 Cadillac DeVille 472 convertible, which I sold in 2018. It had door and console trims that were literally furniture-grade plywood. The finish was shoddy when I bought it so I pulled them out and sanded and refinished just like an old side-table. Stained and varnished and it turned out great. But I don’t think anybody’s made a panel like that in a long time.
Old Apr 12, 2024 | 01:30 PM
therift72's Avatar
I have a set of Robustec ones I took out of my 2021 SE and replaced with the walnut package. Happy to do a deal.
RM
Old Oct 9, 2024 | 03:08 PM
BlueJack's Avatar
7th Gear
If anyone has a set of OEM wood trim, I would love to upgrade my HSE which just came with the standard pleather finish on the center console. Really adore how the wood looks!
Old Oct 9, 2024 | 03:21 PM
CincyRovers's Avatar
You can buy the OEM Rough-Cut Walnut trim from Powerful UK: https://www.powerfuluk.com/collectio...-defender-l663 https://www.powerfuluk.com/collectio...r-l663-110-lhd
Old Oct 9, 2024 | 03:25 PM
BlueJack's Avatar
7th Gear
Appreciate it, I am after the lighter color trim. I am not sure what it is called but the gentleman above posted pictures of it prior to replacing it with carbon. That is the color and finish I am after, such a lovely touch!
Old Oct 9, 2024 | 03:34 PM
The links I attached above are the same trim pieces that were swapped in the first post on this thread. It is the Rough-Cut Walnut veneer. I have it in my car, and the color changes slightly depending on the light as you can see in the photos I have attached below.
Old Oct 9, 2024 | 03:37 PM
BlueJack's Avatar
7th Gear
Looks great!
Old Oct 10, 2024 | 11:20 AM
wcc18999's Avatar
Nice Caddy!
Old Apr 9, 2025 | 11:29 PM
rakusak's Avatar
any chance you still have the Robustec ones for sale?
Old Apr 10, 2025 | 12:48 AM
isugoo's Avatar
I just bought the wood trim for my black Interior (75th). I do not personally prefer wood trims usually but I really like wood trims on LRs.
Especially on my 75th limited, I like the contrast between exposed green exterior color inside of my car with walnut trim (even though it's black interior). And hoping to add more of 'heritage' feel with wood trims.
So far, I installed just door handle only. If I remove E-Torx 11 seat bolts and laying back, everything else will be more straight forward?
What I saw was: remove exposed Torx on the trims and plastic trims are secured with only clips. If you dont mind, can you please confirm?
Thanks,
