Key Fob Stopped Working after Battery Change
I got a dashboard warning that my fob battery needed to be replaced so I did so. Now, the fob no longer transmits. I have to lock and unlock using the manual key and to start the engine, I have to hold the fob ageist the steering column. My other fob works just fine. Yes, it's the correct battery and yes, it's installed in the correct orientation and yes, I've tried a 2nd new battery.
Is there any trick to getting the truck to recognized the fob after a battery change? Not looking forward to spending time at a JLR service center.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Only 2 possibilities
You've broken the fob
You're not installing new battery correctly.
As you've ruled out the latter, it can only be the former.
Thanks in advance
Thanks in advance
Where did you buy the battery? Amazon and many chain stores in the US and Canada have had their supply chains contaminated with fake Duracell and Energizer batteries. Packaging looks almost identical, but it's a crap shoot as to whether they work.
It's probably worth buying another battery from a different source and trying that.
Sometimes the fob just needs to be resynced after a battery change. Try this:
Get in the car, close all doors. Hold the fob right against the steering column and press the start/stop button once (don't press the brake). Then, press and hold the lock button on the fob for a few seconds.
If that doesn't work, the fob itself might have gotten zapped when you changed the battery. It's an odd but known issue. You'll likely need a dealer to reprogram it.
