"Land assist not available" and no power steering on 2023 Defender 130 First Edition
Greetings greetings to one and all... as I figured it would be no surprise I had to come back to this community eventually... After owning the vehicle for one month and it driving like a dream. This morning I woke up to a beautiful surprise.! Upon starting my truck. I received a lane assist not available warning with no peer power steering whatsoever. The car does says that it needs an update. I am attempting to update now. And I will make sure to keep you posted. I am sharing this issue. Because, as you know, a lot of dealers are no help. I found another 20 23 defender 90 owner with the same issue here https://www.landroversonly.com/threa...please.158975/
Does anyone have any suggestions? I will attempt the update and see what happens....
The plus side... I was able to throw my family into the good'ol 2021 Discovery and get them to school on time... no software updates needed!
Eitan (01-11-2023)
Mechano2020 (12-14-2023)
Move the passenger seat forward, disconnect the negative battery terminal using a 10mm wrench. Wait about 10 minutes, reconnect and you should be good to go.
The missing power steering happened to me a few times. I traced my issue to software updates not loading correctly due to poor cell service where I live. I added another WIFI router in the room over our garage. So when I run a software update, I turn off the cellular data in the Defender and instead connect the Defender to the home WIFI. Software updates now load correctly.
The following 3 users liked this post by PaulLR:
Order yourself one of these and keep it in the glove box:
https://www.jbtools.com/knipex-98001...sulated-10-mm/
@PaulLR has the best advice. I keep mine in the pocket of the rear passenger door. This WILL work. But as @nashvegas points out: the long term fix likely takes a Dealer to cure the SSB. Make the appointment, order the wrench, put it in the Defender, use it a few times, you will be back on the road, and then weeks later your Service appt will arrive!
Good luck.
Good luck.
It worked!
I figured after owning discos for many years, there is always a trick. Love this community.
The following 3 users liked this post by DISCOFETA:
You're welcome! Thankfully you have owned discos and can accept the quirks and "personality" that comes with these vehicles. The early Defender owners that came from a Lexus couldn't accept any issues and already sold their Defenders to Carvana.
