Light load setting in TPMS is not allowed
Old May 9, 2021 | 10:51 AM
Easy3's Avatar
Default Light load setting in TPMS is not allowed
I am trying to selecr the light load setting in TPMS. I can get to the correct screen on the instrument panel and can see two settings; normal and light load. However, it will not let me select the light load.
I have dropped the pressure to 38 psi all around but now I get the low pressure notification each time I start the car.
2021 def 110 base with steel wheels
Ideas?
Old May 9, 2021 | 11:18 AM
BRW110's Avatar
I had the exact same issue for several days. I eventually got it to accept the option of shifting to the light load. I’m not 100% sure, but I think the thing that let it change was shifting into gear (out of Park) while stopped. I had been sitting for 5 mins with the car on and in park with no luck. I actually gave up and shifted into drive to leave and then all of a sudden in worked. Not sure if that was the proper fix, but that was the only thing that got it to work for me.
Old May 10, 2021 | 08:04 AM
JesseRohr's Avatar
I had this issue when I switched mine to lower TPMS setting. I had luck with what the SA at my local dealer told me to try.
1. Lock vehicle with normal driving key.
2. Wait ten minutes.
3. Unlock with your spare (less used key).
4. Start and drive somewhere 1-5 miles away.
5. Do not turn off vehicle but do put in park.
6. Attempt Light Load settings update.
This worked for me the very first try after failing 4-5 times with my normally used key.
Old May 10, 2021 | 09:42 AM
Easy3's Avatar
Tried it, but no joy so far.
Old May 10, 2021 | 10:36 AM
Easy3's Avatar
Default Tpms light load still not allowed
I tried both solutions (must confess the service advisor who came up with the spare key bit must be a druid priest muttering magic incantations on th we side) but no luck.
Regards
Old May 18, 2021 | 07:50 AM
Easy3's Avatar
Still trying to set the light load setting for TPMS but no luck with the suggestions so far.
TrioLRowner
Oct 15, 2025 06:03 PM
Disco V
Jun 28, 2020 12:22 AM
Sheilaroumpf
Nov 17, 2018 04:25 PM
Groucho123
Oct 20, 2018 11:10 PM
ndinsmore
Jan 27, 2016 09:47 AM
