Tire Pressure - Which Recommended Setting?
Old Jun 9, 2020 | 03:11 PM
Disco V's Avatar
Default Tire Pressure - Which Recommended Setting?
I running the stock Goodyears on a 2018 HSE si6.
90% of my driving is by myself to and from work.
The car came from the dealer set to normal (heavy) load settings...44 front / 50 rear.
I'm thinking this is too high though...should I be using the light setting?
Interested in the setting that will give me the best tread life.
Also thinking the ride will be more comfortable pressured down a bit.
Thoughts?
Old Jun 9, 2020 | 05:23 PM
andries's Avatar
Most definitely, there are a number of threads on tire pressure.
https://landroverforums.com/forum/ne...ressure-92049/
Basically light load is fine for most situations 34 front and 37 rear. I ended doing 36-38 front & 38-40 rear. Found the ride to be much better and the wear seems much better than the high pressures.
Only downside is that you have to remember to air up when taking 6/7 people or load it for trips.
Did not notice any difference in gas mileage with the light load setting.
Old Jun 9, 2020 | 08:47 PM
LoneStarLR's Avatar
I’m running 2psi above the light load rating as it’s just me and the wife.
I’d leave it at that for luggage too.
No need for the heavy load rating unless you have more than 4 people in it or excessively heavy cargo imho.
Old Jun 28, 2020 | 12:22 AM
Groucho123's Avatar
Yup same as above,
andries
May 11, 2023 01:10 AM
Tucker Woods
Jan 2, 2020 12:31 PM
Laurie Pope
Oct 10, 2019 10:53 AM
TMKaufman
Jun 3, 2011 10:41 PM
cpn LR
Jun 8, 2010 08:46 PM
