Loadspace Rubber Mat vs. Semi-rigid Liner
Old Jun 15, 2021 | 12:57 PM
Akrna's Avatar
Default Loadspace Rubber Mat vs. Semi-rigid Liner
Looking at either the rubber mat (https://accessories.landrover.com/us...#tertiary-tabs) or semi-rigid liner (https://accessories.landrover.com/us...#tertiary-tabs) for the back. Any experience with either of these? It looks like the semi-rigid one has a higher back (by the seats) which may be nice. Can you access the D-Rings on both?
Old Jun 15, 2021 | 01:21 PM
TrioLRowner's Avatar
I have the semi-rigid one. It has cut outs for the set D-rings. It does not work with the sliding D-rings (which I have), but I just leave them in the standard position and it works well.
Yes, the semi-rigid one has high edges, which makes it useful to hold dirt, etc. Also, it is pretty tough. And relatively easy to pull out and dispose of the rocks or sand or mulch or wood splinters or whatever is within it.
It is not pretty -- nor stylish -- nor inexpensive. When we bought it there was not weather tec mats available.
The only use challenge I have with the semi-rigid one is that it cannot be rolled up or otherwise stored in the vehicle anywhere / anyhow, how but in its place ... like the floor. This also means that it is kind of a pain to access the under floor storage, as it kind of just sits in space along with the floor (held up with one hand), while the other hand is digging around under the floor for the desired item.
Enjoy !
Old Jun 15, 2021 | 01:24 PM
Akrna's Avatar
Thanks, that's some helpful color. I've seen some videos of the rubber mat, but nothing on the semi-rigid. Thanks!
alexxxxxxsssss
Mar 10, 2021 08:03 PM
carid
Member Group And Special Buys
Nov 18, 2014 04:40 AM
agthird
Aug 30, 2010 10:09 AM
Willie00d2
Jun 30, 2010 11:43 PM
TheDirtyRover
Feb 19, 2009 03:39 AM
