Locking Car With Engine Running
Old Oct 3, 2022 | 10:40 AM
Not dog Freidly's Avatar
Range Rover is not dog friendly, and RR tells you to use the app. If you live in a city and it works all the time, maybe, but it will just shut off and you don't know it till you get back to your RR. If you live in the mountains the app does not work it is always looking for the car.
Why can't RR come up with a watch (like the RR Sport watch) that you can set for how long you want the car to run and you would be able to lock the car while you run for a rest area break. Also why don't they come up with something for our fur babies that would let us run our RR with the air running the doors locked and a temperature alarm that would call your phone and or honk and turn the auto back on if the temp changed from what you had it set at. My GMC you can lock with air on and it will run for 1 hour before it turns off. Why can't RR do the same thing?
Old Oct 3, 2022 | 05:46 PM
Nuckle's Avatar
This is what we do:
Exit vehicle with key fob in hand, engine running and driver window down
Close door
Reach through window and hit the lock button
Flip the auto window up and pull arm out of the way.
Vehicle is locked and running.
Sucks to have to do it this way but honestly it is not hard and it works.
Old Oct 3, 2022 | 11:41 PM
Yulongtd6's Avatar
Originally Posted by Nuckle
This is what we do:
Close door
Exactly how I do it in the RR and Defender.
Old Oct 4, 2022 | 08:40 AM
GrouseK9's Avatar
Now that you posted this, JLR will find a way to disable it!! Argggg......
Old Oct 5, 2022 | 08:53 AM
sblvro's Avatar
You guys heard it here from me. This will keep the engine running on the locked vehicle. Turn engine on, leave vehicle and lock the vehicle from the lock button in the passenger side. It works all the time. No worries!
Old Nov 19, 2022 | 12:31 AM
Huc's Avatar
Huc
I'm adding a +1 to the previous comment about using the Land Rover App to simply set the temp and start it up remotely when locked. Has worked well here in our tests in the recent cold/snowy conditions here in Colorado. We're setting the temps UP to preheat the vehicle - but I don't imagine there's any reason why setting the temp colder won't work. I did note there appears to be a 30 minute time limit on the remote start program in the APP but that doesn't seem unreasonable. Of course I have haven't tried it also leaving a window cracked for pups in the car but aside from the remote app giving me a warning I can't imagine it'll pose a problem.
Old Nov 20, 2022 | 10:26 PM
Nuckle's Avatar
It shuts off after 30min either way. Left it idling the other day in my hunting lease to keep my beverages cold in the console. 30min in and it shut down.
Old Nov 23, 2025 | 07:18 PM
dragoe00's Avatar
6th Gear
Reviving this to see if anyone has come up with anything new on this topic:
Hello, I know that Land Rover does not allow locking the car after exiting while keeping the engine running. There are some awkward workarounds, like exiting the car with the window down, then reaching in to activate Auto Window Up, but then you have to use the physical key to unlock the door. You can also use the App to restart the car once you exit, but that seems time-consuming and times out. I have not tried the locking from passenger side button as one commenter stated.
I have not been able to find an easy way to just exit the car while the engine is running and use the KeyFob or Door Handle "Touch" to lock the car. (Note: this is possible on all Jeep Vehicles). I suspect this is a EU type regulation for pollution and/or safety thing...
I have seen some older posts asking about this several years ago.
Has anyone found a workaround for this?
Does anyone know if, by installing a Compustar Alarm or another brand, this can be achieved?
Old Nov 24, 2025 | 05:10 AM
PeterA's Avatar
As someone mentioned the easiest way to do this is to turn off the car, exit and (auto) lock, then use the app to remote start the car using the Climate function. It will run for up to 30 minutes. Others have mentioned this carries some risk - the car could shut down or air conditioning could turn to heat, one person said they heard about dogs being killed inside a hot car. I live in SC and have done this a few times for short windows and its worked fine. Its important to have adequate cell reception. I keep the app open in my hand.
Old Jan 3, 2026 | 08:27 PM
dragoe00's Avatar
6th Gear
Thank you for the reply. I am also looking at speaking to others that are more technical then I. I have technical abilities, but I am reading about disabling the Immobilizer and using 3rd party remote starters which I am fine with if as long as it addresses this as well as simply having a Key FOB to enable remote start. That's another EU thing. Which I get, they want to reduce emissions and pollution as well as reduce theft. Three things that I wish they would consider for the US market: Gas Fuel ap on Drivers Side, Remote Start on KEY FOB, Ability to Lock car while running. All things you are able to do on most US made vehicles.
sn1987
Defender
Dec 30, 2022 06:11 PM
Manasez
Defender
Feb 26, 2017 11:34 AM
Landi110
Defender
Feb 19, 2017 03:55 PM
2takearest
Mar 24, 2012 03:43 PM
sn1987
Defender
Sep 5, 2009 11:40 AM
