Locks not working; reset battery
Old Mar 27, 2024 | 10:20 PM
Matty79's Avatar
Unhappy Locks not working; reset battery
Hello all, today my 2023.5 110 X started acting very weird - when I would lock the doors (whether by key fob button, door button, emergency key, or interior buttons) - it would lock, then immediately unlock. Then for a good 30-60 (or more?) seconds, no attempt at locking would work. I tried using the Remote App - same thing; it would lock, then unlock. I tried opening and closing all the doors in case it was oddly thinking one of them was not closed all the way, but that didn't do it.
Finally, when I got home, I pulled out a 10mm wrench as others have suggested and just disconnected the negative for ~10 minutes to reboot everything. When I reconnected it, the locks were working fine (key fob, blade, interior buttons, etc.). However, now I have the following odd symptoms I've noticed so far:
1) None of the cameras work (it will say "Camera Unavailable" when you go into reverse, or hit the Camera button in Pivi) - although the ClearSight mirror works (I think that's just a separate non-integrated camera in the shark fin w/ a wire to the mirror that doubles as a screen?)
2) I have no audio whatsoever - no startup dings, no turn signal tickets, no audio from FM or Sirius XM, nada.
Everything else seems normal - only the cabin light color had to be reset (it was purple, it defaulted(?) to yellow).
I rebooted Pivi while sitting parked - no change to cameras or audio.
For now it's just sitting in the garage; do we think after maybe an hour or two everything will be working normally again? I don't relish driving it tomorrow into tight parking spaces w/o cameras - the odd silence I can deal with (actually it's quite loud because the active noise canceling isn't working).
I do have a dealer appointment for an oil change and for them to look at some oddities w/ the fobs, I think they messed it up when they added a 3rd fob. But it's not until April 9th. I'm in Seattle; my appointment is with the Lynnwood location but I can try the Bellevue or Tacoma dealers if I have to.
Thanks in advance! -Matthew
Old Mar 28, 2024 | 12:44 AM
Matty79's Avatar
Ok - note to self and anyone who does this for the first time... yep, be patient- everything will come back. Not sure how long it took because I went inside and ate dinner and such, so it was over an hour... but I went back out, started it up, got the tones, turn signals made noise, audio worked, etc. Even the windows which wouldn't auto-up were working again fine.
Old Mar 28, 2024 | 06:23 AM
TeddyG's Avatar
there's a fuse for key module, pulling it should work.
Old Mar 28, 2024 | 09:07 AM
Matty79's Avatar
I found that thread after the fact… the 2023 iGUIDE does not show any fuses for the key module. However the 2020 one does.
Old Mar 28, 2024 | 01:35 PM
Defender90NY's Avatar
Originally Posted by Matty79
…actually it's quite loud because the active noise canceling isn't working…
Is there active noise cancellation in all models?
Old Mar 28, 2024 | 04:04 PM
Matty79's Avatar
Honestly, I don't know - I can't find reference to it online - and another post linked below seems to indicate it is NOT active in Defender line-up... but I can tell you it sure sounded very different in our garage w/o the audio system working at all. *shrugs*
https://landroverforums.com/forum/20...ations-114294/
Disco V
Mar 11, 2026 10:44 AM
Tonyc217
Sep 28, 2020 08:56 AM
adb1965
Nov 8, 2016 08:50 AM
OCMike
Oct 25, 2014 07:49 PM
