Low Battery Warning
I had 2023 model as well and purchased this Feb. I had same warning issue and dealer replaced the battery.
As battery issue is known issue and dealer makes more money replacing battery than just testing, it worked to for both (dealer and myself).
I got a new battery and installed all new aftermarket audio but I didn't have any issue since replacement. (I drive defender maybe 2-3x/week only).
So if you have an option (before warranty runs out), I recommend taking it in and getting it replaced.
Today I drove into town (11 miles). There was no low battery warning when I left home. Warning appeared when I shut the vehicle down in town. Battery reading 12.4V. Anyone got any idea what is happening? It seems more likely to be a bad sensor than a bad battery...
Out of warranty. I don't want to replace the battery (only 3 years old!) if the problem is in the sensor that tells me that I have a low battery, and not the battery itself.
Just have the battery tested first to determine if a replacement is needed or not. Then you can start testing related sensors.
It's much more likely that the battery needs replacement than a sensor. Besides, "the sensor" is likely buried in a very expensive module. Unfortunately, 3 years for a battery isn't unheard of, depending on weather and use.
Don't be fooled by a trickle charger making things seem fine. They are almost mandatory if you need to park it for a few weeks, but it's no substitute for a good battery. It could be that the next time you park it without the charger is the time it will refuse to start altogether.
Also, it's a real shame that JLR hasn't given the truck a "camping mode" setting that ignores the doors, etc.
I live in the hot Southwest, and by now the stats on four long term vehicles are that the batteries fail after approximately two years. This is the usual warranty term; sometimes, if I'm lucky, they fail just before the warranty runs out, sometimes right after. Jump starter being carried along into the cold (thankfully, they are smaller now) when the car is parked is the EDC item for all the family members now, regardless of the battery age.
Side story - I replaced the battery on a different brand vehicle myself; the dealer offered the "battery registration" service with the mandatory one hour service charge that exceeded the battery price, I said "**** it, I'd rather spend that on a new battery when the time comes", and neither the car nor the battery noticed it. That battery is now almost two years old, and is showing signs of aging, though CTEK still considers it good.
The stumbling point was that one of them totally missed the battery chemistry, the other couldn't figure it out, and the third didn't even bother to check.Anyone has a battery tester at home they like/trust, btw? Apparently, they're dime a dozen on Amazon now, but I have serious doubts about trustworthiness of something for $29.99.
You didn't mention where you are - this may be "business as usual".
An aside question: For the P400 with the "instant start", does this starter use the 12V system or the 48V system? Even when I get the warning, it starts right up - no sign of struggle whatsoever.
