Many Service Bulletins Solved, and a New One Introduced
Old Sep 7, 2021 | 09:37 AM
Vin's Avatar
Vin
Default Many Service Bulletins Solved, and a New One Introduced
Just picked up my ‘20 from the dealership after they fixed the A-pillar wind noise, the Auto High-beam setting, and replaced the wireless charging hardware, but now the Auto-up on the driver’s side window doesn’t work. Auto-down works, and Auto-up works on the other windows.
It’s always something, but I still think it’s one of the best cars I’ve owned.
Old Sep 7, 2021 | 12:20 PM
umbertob's Avatar
They may have forgotten to reset the auto-up on that window only. Roll the driver side window down, then roll it back up by pulling and holding the window up button until it's completely shut. Momentarily release the button then pull it up again for a second or two, you should hear a faint click. Release and test, auto up should work again. This needs to be done for each window every time you disconnect the battery (or the dealer installs updates, obviously.)
Old Sep 7, 2021 | 03:40 PM
Hoosbest's Avatar
For the A Pillar - apparently there is a new Topix out from a week or two ago that has the dealer can order a "repair kit". (Not just felt tape which doesn't fully work). Did they use that on your fix? Not sure what is in the repair kit - but was told epoxy and a few other things.
Old Sep 7, 2021 | 06:30 PM
TheMoke's Avatar
^^^agree. The service manual has step-step notes on the window reset process. Easier to do yourself than to take it to dealer—unless you have other things to get fixed.
Old Sep 8, 2021 | 09:21 AM
Vin's Avatar
Vin
Thanks umbertob and TheMoke, but the easiest thing was to let it think about it overnight. It worked as intended the next day! I do recall now having to do this to my dearly departed Mercedes once, but my first instinct is to ask the forums because guys like you always have an answer for me! Thanks again.
Hoosbest, the bulletin shown in my work order is JLRTB02058 “for windshield molding modification”. SRO Code 99.01.37. No parts listed.
Coldwater
May 16, 2021 11:56 PM
aoysgelt
Feb 20, 2021 07:44 AM
iandemel
Mar 11, 2015 08:07 PM
R2D2
Sep 16, 2011 08:54 PM
mcneal
Jul 2, 2007 04:13 PM
