Map Update Failure
New owner here of 2022 110 X-D.
I tried to update the maps. I was able to use the HERE app to download the maps to a USB.
I wasn't sure if I had to leave the engine running while it was updating so I just turned on the ignition. After inserting the USB, I got a message saying there was an update available so I pressed "Start". The update started, but of course the ignition turned itself off after a while and the update failed. When I turned on the ignition it said that it had failed and that I should remove the USB and try again. I started the car and inserted the USB, but this time there was no message telling me that it found a map update. I tried several times both with the car running and with just the ignition on, but no go.
I see that the map version in the car is IP31.2.2021.27.37 but I can't find what is the latest version on the LR Pivi Pro site.
Any suggestions?
Any suggestions?
I did try downloading to USB again, but still I don't get a message when I plug it in.
