Marker lamp part number
Old Nov 15, 2022 | 11:47 AM
Drednot's Avatar
Default Marker lamp part number
Recently while maneuvering in a very tight parking garage I scraped the right rear extended wheel arch. The plastic wheel arch has an almost invisible scratch, but the red marker light lens is cracked. Does anyone know if this is the same part as used on the standard wheel arch? I want to order one before I dive into the mud flap/tow hook installation.
Thanks,
Andy
Old Nov 15, 2022 | 01:26 PM
wnewport's Avatar
I removed the lamps from my standard arches before recycling the arches when I installed wide arches. They look the same as the standard ones, although I didn't compare the part numbers, but be warned that they are held in by plastic welds, so they may not be available from the dealer separately. If you saved your old ones, you could try and get them out like I did (dremel tool grinding off melted spots that hold them in) and glue them in place.
Old Nov 15, 2022 | 01:39 PM
Drednot's Avatar
Thanks. I ordered the extended arches with the truck and they were installed at the factory so I don't have any old ones. The lamps for the standard arches are available separately as part number LR135947 but before I lay out $60 I wanted to verify that it would fit. If the markers are different and only come with the extended wheel arch kit then I am screwed.
GavinC
Mar 2, 2023 04:36 PM
jusmax88
Aug 20, 2022 08:02 PM
Jay282
Aug 11, 2022 03:13 PM
Springlandy
Defender
Jan 16, 2022 04:29 PM
nickm347
Jan 15, 2017 05:10 PM
