Mounting Accessories on OEM Expedition Roof Rack (e.g Matrax, shovel, etc)
Old 02-26-2021, 10:52 AM
CaptainPrice's Avatar
Default Mounting Accessories on OEM Expedition Roof Rack (e.g Maxtrax, shovel, etc)
Has anyone figured out the best way to mount Maxtrax on the expedition roof rack either flat or on the side without any custom fabrication? Are there off-the-shelf mounts/t-bolts/accessories that works?
In general, for those of you who has the roof rack, how are you mounting things on it?
Old 02-26-2021, 12:01 PM
JHDefender's Avatar
Lucky8 has what you are looking for.
https://lucky8llc.com/collections/defender-2
The following 2 users liked this post by JHDefender:
paule (05-16-2024), Ryu2021 (03-07-2021)
Old 03-14-2021, 11:46 PM
Tt22's Avatar
3rd Gear
Default Works with Thule wingbar t-bolt accessories - used ski rack, sup and roof box
worked with the accessories that work with the Thule wingbar . The expedition has insert t-bolt openings. Btw save the rubber inserts in the rail it helps eliminate wind noise
Old 05-05-2021, 08:35 AM
johnsonmc2000's Avatar
Default Front runner draw rings
just received these from front runner. Seem to fit perfectly - tie down rings for drawer system.
Craig_RRS2013 (03-31-2022)
Old 05-05-2021, 09:00 AM
Juancl's Avatar
I ordered these from Front Runner and separately ordering t-bolts to replace the bolts that come with to attach them to the expedition rack using the T tracks.
https://www.frontrunneroutfitters.co...nting-kit.html
Old 09-03-2021, 11:51 PM
Count Laszlo's Avatar
Anyone know how to fix a full sized spare up on the OEM Expedition Rack? Thanks!
Old 09-04-2021, 06:35 AM
Juancl's Avatar
i would try this, but you would need to get T-bolts that work with the OEM rack (Thule or Rhino Rack) to fix it to the rack.
https://www.frontrunneroutfitters.co...eel-clamp.html
Old 09-04-2021, 11:08 AM
Genius, thank you!!!
Old 09-05-2021, 06:42 AM
4Corsa's Avatar
Looks like that would work nicely. The Defenders that we’re used on the African press expedition all seemed to have tires mounted on the roof rack.
The following 2 users liked this post by 4Corsa:
GrouseK9 (09-05-2021), HI Rover (09-10-2021)
Old 09-05-2021, 11:47 AM
Yes, exactly what I have been using for reference.
Quick Reply: Mounting Accessories on OEM Expedition Roof Rack (e.g Matrax, shovel, etc)
