Mounting Accessories on OEM Expedition Roof Rack (e.g Matrax, shovel, etc)
Old Feb 26, 2021 | 10:52 AM
CaptainPrice's Avatar
Default Mounting Accessories on OEM Expedition Roof Rack (e.g Maxtrax, shovel, etc)
Has anyone figured out the best way to mount Maxtrax on the expedition roof rack either flat or on the side without any custom fabrication? Are there off-the-shelf mounts/t-bolts/accessories that works?
In general, for those of you who has the roof rack, how are you mounting things on it?
Old Feb 26, 2021 | 12:01 PM
JHDefender's Avatar
Lucky8 has what you are looking for.
https://lucky8llc.com/collections/defender-2
Old Mar 14, 2021 | 11:46 PM
Tt22's Avatar
3rd Gear
Default Works with Thule wingbar t-bolt accessories - used ski rack, sup and roof box
worked with the accessories that work with the Thule wingbar . The expedition has insert t-bolt openings. Btw save the rubber inserts in the rail it helps eliminate wind noise
Old May 5, 2021 | 08:35 AM
johnsonmc2000's Avatar
Default Front runner draw rings
just received these from front runner. Seem to fit perfectly - tie down rings for drawer system.
Old May 5, 2021 | 09:00 AM
Juancl's Avatar
I ordered these from Front Runner and separately ordering t-bolts to replace the bolts that come with to attach them to the expedition rack using the T tracks.
https://www.frontrunneroutfitters.co...nting-kit.html
Old Sep 3, 2021 | 11:51 PM
Count Laszlo's Avatar
Anyone know how to fix a full sized spare up on the OEM Expedition Rack? Thanks!
Old Sep 4, 2021 | 06:35 AM
Juancl's Avatar
i would try this, but you would need to get T-bolts that work with the OEM rack (Thule or Rhino Rack) to fix it to the rack.
https://www.frontrunneroutfitters.co...eel-clamp.html
Old Sep 4, 2021 | 11:08 AM
Genius, thank you!!!
Old Sep 5, 2021 | 06:42 AM
4Corsa's Avatar
Looks like that would work nicely. The Defenders that we’re used on the African press expedition all seemed to have tires mounted on the roof rack.
Old Sep 5, 2021 | 11:47 AM
Yes, exactly what I have been using for reference.
