My 2020 110 P400 Mod Journal
Old Feb 24, 2021 | 11:58 AM
  #51
Defender13's Avatar
Jesse - Where did you get the 110 Badge on the back left window? I want to get one too. Thanks
Old Mar 16, 2021 | 01:36 PM
  #52
drcoop's Avatar
Quick question, sorry... Is that "Defender 110" badge on your rear window a decal or did you adhere one of the original steel badges to the window? Thanks!
Old Mar 28, 2021 | 05:06 PM
  #53
karlos73's Avatar
Are you planning on doing any engine flashing to get more BHP?
Old Mar 29, 2021 | 06:54 AM
  #54
RedAustinIX's Avatar
Defender13 -- I think the rear Land Rover badge is part of the Lucky8 "Square Delete Kit"
Old Mar 29, 2021 | 06:55 AM
  #55
Landy718's Avatar
https://www.roversnorth.com/parts/rn...saAhtsEALw_wcB
Old Mar 29, 2021 | 02:14 PM
  #56
JesseRohr's Avatar
Mine is actually a decal someone had on Etsy, those metal badges look awesome though.
Old Mar 29, 2021 | 03:52 PM
  #57
NoGaBiker's Avatar
Yeah, they sure do! May have to get one of those on order. I bought a pair of fender badges off an old Jeep Wagoneer from the early 70s, refurbed and mounted on the sides of my 2014 Wrangler.
Old Mar 30, 2021 | 04:37 PM
  #58
Ehloo's Avatar
Hey Jesse,
i just ordered the same rack and thought about something. Are you still able to open your sunroof with the rack
Next phases:
The wheel is a 20x8.5 with 41.5mm offset. With the spacers the wheel is pushed out 30mm creating a 20x8.5 with 11.5mm offset.
H&R makes a set of 25mm spacers as well that would work. 20x8.5 with 16.5mm offset would be that functional setup.
25mm set - Part number 50757257 (you need two)
30mm set - Part number 60757257 (you need two)
30mm wheel spacers and new BFG K02 Tires:
Windows tinted 15%:
Nitto Ridge Grapplers swapped in instead of the BFG after three were warrantied for out of spec shape. Also JLR factory Raised Air Intake and Cross Bars installed:
Proud Rhino 1.0 lift arms installed:
FrontRunner Slimline 2 rack (For OEM Rails) installed:
Old May 28, 2021 | 05:23 PM
  #59
Zando504's Avatar
Awesome build! Did the Nitto’s fit on your stock wheels (with out rubbing etc) before the lift was added?
Old Jul 4, 2021 | 08:01 PM
  #60
GrouseK9's Avatar
@JesseRohr - Why did you move from the 1" lift to the 2" lift? Was it to make it look even cooler or were you having any rubbing issues with the K02's or Nitto's? Great build!
