New 2020 Defender Lift Kit by Johnson Rods
Old Mar 20, 2024 | 08:04 AM
  #171
Ratledge's Avatar
It moves the sensor position 1.5"
It still has the same range of motion, although you move the top and bottom.
Old Mar 21, 2024 | 04:22 PM
  #172
Johnson Rods's Avatar
LR Forum Vendor
The lift rods give you 1.5 inches full time and in the off road mode will go partially into the extended mode. If you get high centered, it can still go a bit higher.
33 inches it the max I normally recommend, you may get some very minor rub with 33.2 but it can be adjusted for.
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Mar 21, 2024 | 04:25 PM
  #173
LR Forum Vendor
Defender running 1.5 inch Johnson Rod lift with BFG KO2 tires in 275-55-20 and our Seamak Wheels available on the website.
Check out the lift and wheels options in the link below:
__________________
Old Apr 4, 2024 | 04:41 PM
  #174
LR Forum Vendor
Defender running 275-60-20 BFG KO2 tires with 1.5 inch Johnson Rod lift kit.
Check out our lift and wheel options in the link below.
__________________
Old Apr 22, 2024 | 10:53 PM
  #175
gb1044's Avatar
My 24 110 x running 275/60 20 with jhonson rods 1inch tires are Falken wild peaks at4w no rubbing at all in normal or off road height the tiniest bit in access mode but I don't use that anyway, truck rides great
Old Apr 24, 2024 | 03:02 PM
  #176
LR Forum Vendor
Default Defender lifted
2022 Defender Se X-dynamic with 1.5 inch Johnson Rod lift, 33" Milestar Patagonia XT tires shown in off road height and normal height.
Check out our lift and wheel options: Johnsonrods.com
__________________
Old May 6, 2024 | 08:24 PM
  #177
YS78's Avatar
4th Gear
Default Installation
Can I install the rods in my house? Do I need to.take it to the shop ?
any installation guide???
thnks
Old May 22, 2024 | 06:04 PM
  #178
LR Forum Vendor
Defender with 285-50-20 BFG KO2 tires and our Johnson Rod 1.5 inch lift kit
Click here for more lift and wheel options: Johnson Rods.com
__________________
Old May 24, 2024 | 01:39 PM
  #179
curb-optional's Avatar
So I think the KO2s look great! Question: many of the photos have the KOs on 20" rims. If you get a 1.5" lift on 20"s, is it possible to get a smaller lift and switch to an 18" rim? Is it one of those problems where you need the 20"s for the brake calipers on a P400?
Old May 25, 2024 | 08:44 AM
  #180
DonMitsu's Avatar
Lucky8 sells a rear brake caliper swap that allows some 18” wheels on the P400. The front brakes fit just fine, the rear caliper must either be ground down or swapped. The replacement calipers are LR calipers using the same pad and piston size, so it really begs the question why the rear caliper was designed to be so bulky.
