New 2020 Defender Lift Kit by Johnson Rods
Old Dec 2, 2020 | 01:26 PM
  #41
Johnson Rods's Avatar
LR Forum Vendor
Here is another example of 275-60-20 Nitto Ridge Grapplers with our 1.5 lift
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Dec 5, 2020 | 09:50 PM
  #42
jscsj's Avatar
Default Ok to use with 19's?
I have a new defender, have 19in rims with the Wrangler All Terrain Adventures on them (31in). The dealer was listing off a bunch of options to modify my vehicle and he mentioned putting the johnson rods in. My question is, would they look funny (too much space) given every picture in this forum has rods installed with either 20in or 22in rims with much larger tires?
On the Johnson Rods website I looked up the tires and and it says "no lift required" for my specs. Maybe I should hold off till I get larger rims and tires?
What do you guys think?
Here’s the current setup
Old Dec 6, 2020 | 04:51 AM
  #43
jscsj's Avatar
Deleted duplicate post
Old Dec 19, 2020 | 03:23 PM
  #44
LR Forum Vendor
The 19 inch wheels should have a 255-65-19 mounted which is 32 inches.
You can definitely use the lift and it will look just fine. There are not any larger tires in 19.
If you go to a 20 inch wheel you can run 275-60-20 which is 33 inches.
Here is a Defender with stock wheels and the lift in off road mode.
Normal mode would be just 1.5 inches higher than yours sits now. It will look good.
Stock 32's in off road mode. 1.5 inch lift
__________________
Old Dec 19, 2020 | 03:26 PM
  #45
LR Forum Vendor
Another nice build with Johnson Rods
Ask your Land Rover dealer to do the install.
285-45-22 Nitto Ridge Grapplers
__________________
Old Dec 28, 2020 | 08:54 PM
  #46
SmokinV10's Avatar
Does air leak out when parked overnight at standard height with the lift? My fronts always seem to drop and inch or two overnight.
Old Jan 1, 2021 | 05:53 PM
  #47
JesseRohr's Avatar
Lower ambient air pressure means lower PSI as it sits over night. This doesn't seem that odd to me given what the air can do after the sun goes down.
Old Jan 13, 2021 | 04:06 PM
  #48
DallasBBQ's Avatar
Can the rods be easily installed without removing the tires? Does anyone have a video showing installation on the new Defender?
Old Jan 13, 2021 | 07:49 PM
  #49
Iceman153's Avatar
will the 275/55R20 goodyear duratracs fit without lift? They are still a 32" tire, but have the extra width of the 33" 275/60R20. I haven't seen many examples of people using this size, but it is listed on the goodyear website. Everyone seems to go with the 275/60R20's with lift, or the 255/60R20 without.
Old Jan 18, 2021 | 01:48 PM
  #50
LR Forum Vendor
You can change the front without removing the tire, but I recommend removing the tire to get access to rear rods.
__________________
