New 2020 Defender Lift Kit by Johnson Rods
Old Jan 18, 2021 | 01:50 PM
  #51
Johnson Rods's Avatar
LR Forum Vendor
Yes, you can fit the 275-55-20 without a lift. It does look better with it however.
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Jan 18, 2021 | 02:29 PM
  #52
LR Forum Vendor
Fun in the mud using our Johnson Rod lift with larger 33 inch tires.
Check our links below for more info and to order a set for your Defender.
Ask your Land Rover dealer to install Johnson Rods.
__________________
Old Jan 26, 2021 | 01:27 PM
  #53
Iceman153's Avatar
Thanks! Yeah it does look great with the rods, but good to know i can install the rods after the tires.
Old Feb 2, 2021 | 09:08 AM
  #54
Triet Nguyen's Avatar
4th Gear
guys running spacers are you replacing your studds also?
Old Feb 7, 2021 | 10:44 PM
  #55
DEFX's Avatar
JR 1.5" w BFG KO2 275/60/20. Big improvement over factory A/T tires in snow and dirt and maybe even on road. Fits perfect, however, I think any spacers or wider offset would rub w this size tire.
Old Feb 11, 2021 | 08:29 AM
  #56
Bukmar's Avatar
I was told by a dealer (during purchase negotiations) that they would not install the Johnson Rods because it would void the warranty. I see that there is a a 110S listed on the LR website that has Johnson Rods as a dealer installed accessory. I know there is one post in this thread that addresses this, but I would be rather upset if I bought a car off the lot where the dealer installed the Johnson Rods (not on my request) and then was told by LR that this voided any warranty issue that might arise with the suspension or related aspects. What’s the truth here?
Old Feb 11, 2021 | 08:42 PM
  #57
DEFX's Avatar
There are some dealers who will not install them, but there are others that will. I took delivery of my vehicle from a dealer who wouldn't install anything aftermarket, including the rods. I then had another dealer install them along with new tires... their comment was that if there were suspension related problems JLR could deny any claims, but their dealership would basically look the other way... I believe there has been some more detailed conversations about warranty, earlier in this thread. It seems like anything aftermarket is technically a breach of warranty terms. However, In practice, it may not be enforced. I also you can keep the factory rods, and it's an easy switch back if there were ever any issues. Personally, after seeing what the rods do and that they are not putting any strain on the air suspension, it is a risk I am comfortable taking. Might be worth looking into the LR3 / 4 forums to see if anyone has had warranty claim denials, as there are some older high mileage vehicles using rod lifts...
Old Mar 2, 2021 | 01:28 PM
  #58
LR Forum Vendor
Some dealers just don't do any after market installs, however many of those send them to shops they work with and know its being done.
We have many dealers that are happy to install them and stand by the installation. Check with other dealers in your area.
__________________
Old Mar 11, 2021 | 03:55 PM
  #59
LR Forum Vendor
275-60-20 (33") Nitto Ridge Grappler tires with our 1.5 inch Johnson Rod lift.
check our profile information below for more.
__________________
Old Mar 20, 2021 | 01:00 PM
  #60
Brak's Avatar
3rd Gear
Default Why take em off?
Originally Posted by TexasLandmark
Yes but I don't really think that "over-inflating" is exactlly what I would call it. Think of them as "filling up more" rather than "stretching a balloon". The bags have quite a bit of travel range... you will loose some droop/articulation though. I have some on a disco 5. I put the lift rods on when we have our larger offroad tireset on the vehicle for road driving... if any offroading where tire lift is going to be done, I swap back to stock rods and put it an offroad mode with the preset factory lift/higher air fill. Since the disco and defender share most of that stuff, I imagine that the installation of these rods is almost the same... it takes me less than 10 minutes to change from stock rods to lift rods... or back.
Excellent clarification, thanks. Can you please explain further why you'd take them off for off roading. If I understand correctly, it jusr increases all three heights by 1.5". So wouldnt that help with approach angles, etc, even in off road height setting to have an additional 1.5"?
