New Build guidance needed... planning to order
Old Jan 13, 2023 | 10:49 AM
  #21
mrego's Avatar
Originally Posted by UN-Blank
Interesting. i dislike immensely "specialty tires" that are developed between car and tire manufacturers. Is this specific to the 19" wheels? Is there a better option?
This is good info. Does the air suspension limit the ability to have a lift installed? yes, i know ive said it wont go off-road... What is LR's reason for the air suspension? i know many brands use it for load leveling...
IMO, and oddly enough, in Land Rovers it is actually easier to install a lift with the air suspension, when compared to coil suspensions. You just buy the lift rods, pop the old ones out and install the new ones. There is a stick thread on lifts right on top of the Forum page. The air suspension is to allow more clearance when off-roading without sacrificing drivability on road when you do not need the additional clearance and would rather not drive a big top heavy boat lumbering from one corner to the other. I even believe that at certain high speeds (70mph or 80mph plus) the Defender with air suspension will squat a bit to increase stability (can't confirm that though).
Old Jan 13, 2023 | 11:01 AM
  #22
GavinC's Avatar
Lose the 19" and get 18". Much better and a smarter choice. Two very nice OEM rim options at no cost on the S
Oodles of tire choices in all types in 18".
Go 19" and you get to choose from the 3 LR offerings for on-road and off. None are any good. LR seem to be the only manufacturer using these oddball rims. No other options.
Not getting 18"s on an S or base is a mistake.
Old Jan 13, 2023 | 11:03 AM
  #23
PaulLR's Avatar
Many very helpful responses. Couple things to respond to,
1. ive looked at used and can buy more of what i want for the same or less money.
2. i want 4 doors. i dont care about the power as long as it can get out of its own way. i have other cars that have power. the LR will be driven mostly in town, maybe on a trip here or there. the worst conditions it will see will probably be snow and that is mostly if i drive it to mountains or something in the winter. i will not take it rock crawling, etc. i might tow a small trailer. i do not own anything that requires towing and if i did i have a suburban that would do the job.
unlike some of you, i drive mostly black cars and always have. i totally appreciate that others are tired of it but i just love it on anything. to me, all black makes the crappiest looking are look decent!
Here is my initial attempt at a build:
I would switch to 18" or 20" wheels. The oddball 19" size leaves you with very few tire options.
Old Jan 13, 2023 | 12:05 PM
  #24
UN-Blank's Avatar
such good info. thanks all!
Old Jan 13, 2023 | 10:51 PM
  #25
sarek's Avatar
Originally Posted by mrego
FWIW, if you think about reselling in the near future, you should consider adding the air suspension. When I was searching for mine, all the sales people I came across told me the ones in coils were collecting dust in the lots.
That is just a sales tactic. Completely false.
Old Jan 15, 2023 | 04:35 PM
  #26
GrouseK9's Avatar
If I had a "do over", I would have ordered the 110-SE and upgraded the items I wanted. Would have had a much better build, proper colors (white roof), and what I wanted for no more $$. But I fell for an over-order. Don't get me wrong, LOVE my 110 - I just think some things are overrated by the sales team to get better commission $'s.
Old Jan 15, 2023 | 10:02 PM
  #27
Vadiable Paradox's Avatar
Originally Posted by verrilli
I think you're going to get many different opinions on this, but I'll give mine.
options I have that I don't like
- roof rack - too much noise so I took it off
I have the same reservations about it, but we heed to haul big flat stuff in the city often enough so I'm considering buying it; just wondering - was it a 3 person job like instructions here say, or you can get away with two? Did you get rid of it, or are you putting it on for long trail runs?
- side ladder or snorkel - they probably add noise and they don't look good in my opinion
I wonder if someone in this thread can answer - I'm considering the snorkel because of a lot of fine dust on trails I run, does the snorkel do a good job on filtering that out?
Old Jan 16, 2023 | 06:43 AM
  #28
verrilli's Avatar
I did it with one person by stringing it up from the rafters of my carport with some tie-down straps. I can store it there and back under it and lower it down for installation when needed.
Old Jan 18, 2023 | 06:47 PM
  #29
UN-Blank's Avatar
so im getting feedback from a dealer that the 4 cylinders cant be ordered currently? what say ye braintrust?
Old Jan 18, 2023 | 06:54 PM
  #30
sarek's Avatar
Typically dealers get allocations and will steer you towards what is more readily available to them. I believe if u order a 6cyl, currently you will get it sooner. But i believe u can order a 4 cylinder, it will just take a lot longer to get.
