New Extruded Aluminum Rock Sliders
Old Mar 27, 2026 | 05:34 AM
A1C6's Avatar
Any updates on whether these fit the OCTA?
Old Mar 27, 2026 | 05:49 AM
sarek's Avatar
Originally Posted by RH5555
@sarek did you consider hard anodizing your rock sliders instead of powder coating? I've found anodizing to be the most durable finish for aluminum field equipment.
In a sense we are basically doing anodizing right before we powder coat. The ECC (electro ceramic coating) process is very similar. Finding companies with a large enough anodizing tank for something of this size can be tricky. We are fortunate to have a furniture manufacturer in our area that has an entire building dedicated to ECC.
The drawbacks to leaving a hard anodized finish will be chemical resistance and UV resistance. We can also provide them raw aluminum if the end user would like to take care of finish coating . The powder coating also has a bit of texture in it that helps with traction while stepping on them. Anodized finished will be very slick.
Old Mar 27, 2026 | 05:51 AM
sarek's Avatar
We can easily confirm fitment if someone would like to bring their vehicle by to double check. It's very likely they will fit especially in the base form, however it is not yet been confirmed. If an octa owner would like to take their plastic seals off and shoot me some photos, I can probably confirm this fitment
Old Mar 27, 2026 | 05:22 PM
A1C6's Avatar
Dropping past wouldn’t be an option for me as there is about 14,000 km of ocean between as.
Ill have a look at removing some bits, could you confirm which plastic seals you are referring to?
umbertob
Mar 24, 2026 01:50 PM
JBelt01
Jan 6, 2026 01:44 PM
jwest
Nov 13, 2025 01:32 AM
sarek
Nov 27, 2022 01:30 PM
drowssap
Aug 29, 2013 11:00 AM
