No Lift tire size guide (work in progress)
Old Oct 26, 2021 | 01:50 PM
  #221
Auch's Avatar
Originally Posted by GetOutTheWay
Seriously? I can remove that "apparatus"? And then put on 19's? Now I will really have to crawl under and grub about if that might work. I just want to make sure that it's not part of my air suspension is all! (I really don't like the stock wheels personally, as they are a bit boring and "stick out too much" which will rub on rocks and etc.) I'am a good driver, but you know, I can just see airing down the current tires even just a bit ....and suddenly...you are left with nothing more than a cantaloupe rind for tires. Thank you for the info. I'll be checking how to do, checking back on this thread too for ideas. I still need to look at what offsets for aftermarket wheels. The OEM +41 is a strange number. I like a couple +35's offsets....I'm sure some thread here will help with that. Again, TY for the info
Hi, Did you find out what the purpose of that hockey puck type thing is for and were you able to remove it with no issue and get the rims installed? I have a P300 with factory 20" rims and trying downsize to 18"'s for the winter but my P300 also has that same thing on the front wheels.
Old Oct 26, 2021 | 02:26 PM
  #222
TheLittleEngineThatCould's Avatar
The aluminum “hockey puck” pieces (actually like curved half pucks) are simple bolt-on, bolt off jobs.
They are installed on P300s that run 20” wheels because the P300s run smaller brakes than the P400s, so when running the larger wheels, there is a larger empty space inside of the rim opposite the caliper.
The thinking was that mud could potentially fill and pack into this area during off-roading, possibly resulting in the wheel becoming unbalanced… so they bolted on the puck to fill in some of the space.
The puck is not needed on P300s that run 18” wheels, as the empty space opposite the caliper is small enough that LR engineers didn’t feel there was a threat of unbalancing due to packed mud… so those trucks do not come fitted with them.
I removed my P300’s factory 20” wheels (Style 5098) and put on the factory 18” alloys (Style 5094)… the only modification necessary was the removal of the pucks.
Before:
And after:
This was before I removed the mud flaps
Old Oct 30, 2021 | 11:59 PM
  #223
Bigwood's Avatar
The rig looks great! Is that panga green? Pm me if you want to sell the mud flaps.
Old Oct 31, 2021 | 10:18 AM
  #224
spikemd's Avatar
18s are the way to go!! I even think the style of those 18s look better than the 20s. More sidewall is definitely better offroad.
Old Oct 31, 2021 | 02:33 PM
  #225
mammoth's Avatar
Has anyone tried Falken Wildpeaks in size 265/70R18 on the tuffant wheels? They're 32.6" x 10.8"
Old Oct 31, 2021 | 02:55 PM
  #226
D90Hope's Avatar
This was a really helpful bit of information. Thanks also for sharing the visuals, your D90 looks great. I made the rookie mistake of ordering mine with the 19" wheels; I'll definitely be downsizing so that I can get a more aggressive tire.
Old Nov 1, 2021 | 11:29 AM
  #227
umbertob's Avatar
It's a rookie mistake only if you own a P300. If you have a P400, you did the best you could... I have a P400 (D110) and the 255/65R19 Goodyear Wrangler Duratracs are turning out to be surprisingly good tires, actually - thank goodness for that, since there are no suitable alternatives for off-roading. Not quite ready to downsize the rear brake calipers to fit 18s, may do so after my factory warranty is up.
Old Nov 7, 2021 | 06:29 PM
  #228
Defendit..'s Avatar
Default Twin Monotube Projekt AT
New for Defender in 20", They also make 18" for the VW T5/6 in ET42, Bore needs to be extended from 65 to 72,6
https://twin-monotube-projekt.de/pro...nmatt-schwarz/
Old Nov 9, 2021 | 04:40 PM
  #229
DPReef's Avatar
Anyone fit 305/50/R20 (Eg. Nitto Ridge Grapler) on a 20x9.5" rim? The tire is 32" but wider by .8".
I'm coming from 285/45/R22 right now on a P400 with no rub that i can tell, see, or feel.
Old Nov 10, 2021 | 07:17 AM
  #230
GrouseK9's Avatar
@DPReef - What app/site did you use for that image? Thanks.
