Non-tow package from factory have brake controller pig-tail?
I've got a 2021 110 p400 that came without the factory tow package. Bought the parts needed and installed them myself then had Land Rover flash the software so I've got the 4 & 7 pin connectors, module and hitch receiver all good to go. Worked great with a u-haul rental that used the 4 pin. However now we're getting an Airstream and I need to install a brake controller but am getting mixed results on whether or not the under-dash pigtail connector for the controller is going to be there or not... Some say you need to run one up there and others say it should be there already. Anyone know for sure? Thanks!
That was my thought as well. I think others on the internet might just not know what the hell they are talking about when they said you have to run a wire back yourself. Once I'm done work I'll stuff myself under there and find out for certain.
My 90 did not come with a tow hich from the factory. I installed the kit and installed a brake controller. The plug is in the knee bolster pedal area. Use a ford style brake controller adapter and use any contoller you desire.
