Not much out there for the factory 22" Wheels
Old Jan 27, 2024 | 09:19 AM
Chris.Gio's Avatar
Originally Posted by crewcabrob
Both had 1.5" lift rods installed and it will rub in access height but not in any other selected height.
Rob
wonder if these would rub (33.7)…
Old Feb 5, 2024 | 02:59 PM
starbai's Avatar
Originally Posted by DPReef
Hey, thats a picture of my car. I have 285/45/22 on there now with spacers ( I think they are 30mm). There is a slight rub on some of the vent fins on the lower part of the wheel well, i cut them off and it was fine. The 25mm spacer woudln't fit w/o triming the lug nut and I wasn't wanting to do that.
Moved the intercooler and about to put 35s. Yes, it's ridiculous but i can and will. I take my car on dirt/gravel roads, farmland, fields, big bend national park and mess around al the time. Works for me. I don't do real rock climbing but i got rock sliders and a winch anyways! you do you....
PS @DPReef I just re read this months later and I noticed you said you couldn't fit the 25mm spacer without trimming. I do not know that this is true. I'm now running 20mm spacers on the front with the factory 22s and I've had no trouble. Just curious, am I missing something?
Old Apr 3, 2024 | 12:57 PM
Tamer76's Avatar
There are many All Terrain and other tires available if you go up in tire size from the stock 275/45/22 to 285/45/22 on the stock suspension, no spacers or lift rods with no rubbing. Many have went to the 285/45/22 with no issues on the Defender.
Old Apr 8, 2024 | 04:00 AM
kiwi.tango's Avatar
This is what I used for my setup. No regrets
Used these spacers 20. mm front, 25mm rear
https://www.bonoss.com/product/bonos...nder-l663-2019
Bull bar and winch
https://rhino4x4.com.au/product/bar-defender-20/
Winch Rhino 12,000 lb
Tires:
https://www.generaltire4x4.co.nz/pro...e-grabber-at3/
I tried the 285/45/22, but it was too tight on the front with more of the aux radiator forward.
These tires are a compromise as they do not offer the sidewall protection I would have liked.
Wrapped the sides to present brush scratches.
Old Apr 8, 2024 | 08:43 AM
starbai's Avatar
Bull bar and winch
Tires:
looks great. what are the specs on the wheels? 22" sure, but width and offset? Just trying to do the math to account for your issues with the 285s being too big. Question when you had those issues, did you have them with the spacers on? and if so, what were the width of the spacers you were running inf ront?
Old May 10, 2024 | 10:18 AM
JJOB's Avatar
Hi, thank you for the info. I am looking to keep the 22'' stock rims and add larger a/t tires with a 1.5'' lift kit. I can add spacers if need be. I do not want any trimming to happen.
Can you please confirm you are 33x12.5?
thank you very much,
Old May 18, 2024 | 05:22 PM
justencucu's Avatar
Hey! Do you have a defender S, SE, or X? So I have a P400 SE, came with the 20" wheels. Also have a 2 inch proud rhino lift on it. I really like the 22", and i was told all the defender's have the same bolt pattern and stuff that i can put the 22" on my SE. I bought 285/45/R22 ridge grapplers and the 22" inch tires, took them to 3 different tire shops to mount and balance, and before they even put the tires on the wheels, they tested the wheel fitment, and they all said they wont fit. Any ideas?
John Drover
Oct 27, 2024 08:22 AM
AuZZZie
May 22, 2011 01:45 AM
Shaymer
Nov 15, 2009 11:27 PM
cardinal77
Jun 12, 2009 07:27 AM
rangerover22asanti
Tires
Mar 31, 2007 06:18 PM
