Octa GAPIId programming
Old Aug 22, 2025 | 09:12 AM
Ggils2324's Avatar
Default Octa GAPIId programming
For this Octa owners…have you used the GAPIId tool to do any activations and if so, what have you done?
Old Aug 22, 2025 | 10:36 AM
CincyRovers's Avatar
Since the OCTA comes with just about everything standard, there aren't really any upgrades that can be activated. However, features like allowing both high beams and fog lights, Wi-Fi hotspot, global close etc. can be activated.
Old Aug 22, 2025 | 08:07 PM
Jim 90's Avatar
Auto start stop!!!
Old Aug 24, 2025 | 12:52 PM
PNW Rover's Avatar
As CincyRovers said, the OCTA comes with pretty much everything out of the box. Mine already had Wi-Fi and hotspot already enabled and I think even global close was enabled and available for selection on the Pivi (it is now either way).
Ones you may wish to consider:
High beam with fog
Auto Stop/Start disable
Chauffeur Mode MultiCAN-665 (to adjust passenger seat position from display, helpful when a passenger gets out and the front passenger seat is left in disarray)
Enable both front microphones EUCD-126 Microphone
Beltminder MultiCAN-717 "minimum" and not completely off for shortened bong time. Some fully disable it but that could create a problem.
Remote tailgate release with fob MultiCAN‑744
Old Aug 25, 2025 | 03:15 AM
pjeski's Avatar
I’m curious. What problem could fully disabling the beltminder cause?
Old Aug 25, 2025 | 10:03 AM
Ggils2324's Avatar
Could you please share the settings for: 1) Chauffeur mode; and 2) Microphone enablement.
Old Aug 25, 2025 | 02:29 PM
PNW Rover's Avatar
Oh I don't know, maybe no one realizes a seat belt is not buckled because there is no gong at all and then that passenger dies in a fiery crash?
Old Aug 25, 2025 | 03:42 PM
A1C6's Avatar
High beam with fog
I don't understand why people have a phobia of seat belts. They are there to keep you safe, and have proven to save lives, so why not just wear them? Sure, if you are wading or on a car boat there is definately reasons to have them off, but why don't you just ignore the dinging for a bit?
Old Aug 26, 2025 | 12:14 AM
PNW Rover's Avatar
It's not a phobia of seatbelts in my case and likely others. The "minimum" setting vs a fully off setting works very well, one case example would be the vehicle is parked at a store and the passenger exits to run in to grab some groceries, the driver remains in the parked vehicle but takes their seatbelt off to retrieve a phone out of pocket or for comfort. This then fires off the seatbelt minder bong from which there is no recovery without a restart to my knowledge. However, if the bong is set for minimum it will only sound for a time (longer than you think) and will then silence itself.
Old Aug 26, 2025 | 12:39 AM
PNW Rover's Avatar
What to change (GAP IIDTool – CCF)
1) Chauffeur Mode (MY24+ only)
  • Code:
    MultiCAN-665 ChaffeurMode
    Fitted.
  • Code:
    MultiCAN-853 TS Sec Seat Movement
    Touch Screen Control of Secondary Seat Movement – Fitted.
2) Both front microphones (front only, not rear)
  • Code:
    EUCD-126 Microphone
    Two Microphones (Front Only).
    (For reference, many cars ship as Microphone (Driver Only); the “all mics” option is Four Microphones (Two Front & Two Rear).
alexanderrea
Jul 25, 2024 06:10 PM
keninnc
Apr 19, 2022 09:18 AM
2006LR3
Sep 19, 2017 06:30 AM
Colb.45
Jun 2, 2015 11:51 AM
Oasisplayer311
May 7, 2015 01:13 AM
