View Poll Results: What oil change interval are you using?
Factory Interval of 21,000 miles
8.96%
about 15,000 miles
1.49%
about 10,000 miles
33
49.25%
about 5,000 miles
24
35.82%
other - comment what that is
4.48%
Voters: 67. You may not vote on this poll
Oil change interval poll
Old Jul 31, 2024 | 04:51 PM
BritCars's Avatar
On my Discovery with the V6 3.0 engine we did annual which was 16,000 miles. Took the truck to 100k miles with zero issues. Did an oil analysis a couple of times that suggested there was more life in the oil. Lots of highway of course and not heavy duty towing. But shows these engines and modern oils are very different from before
I would have no hesitation with similar and annual on these new engines too. Just for our 130X this month and that's currently my plan. Nothing wrong with more frequent but oil analysis and research would suggest it's not needed.
Old Jul 31, 2024 | 05:54 PM
v35's Avatar
v35
Every 10k for me.
Old Jul 31, 2024 | 07:37 PM
NHnorthhills's Avatar
8th Gear
First oil change 1,000 miles, all others 5,000 miles.
Old Jul 31, 2024 | 08:45 PM
Retiredone's Avatar
Did my first oil change at 2000 miles and the second at 4000 after an 18 hour road trip. Plan to do the next one at 10,000.
Old Aug 1, 2024 | 07:09 AM
PaulLR's Avatar
FWIW, JLR recommended a 15,000 mile oil change interval on the LR4 V8. I cut it in half to changing the oil every 7500 miles and my timing chain guides were still quiet at 200,000 miles. Others that followed the 15,000 change interval had timing chain guide issues by 100,000. Based on this, I'm going with 10,000 mile oil change intervals on our Defenders.
Old Aug 1, 2024 | 10:54 PM
skl49's Avatar
Just got my oil change kit (for the V8) with the proper oil and plan on doing it around 2K miles or so. Has 1300 on it now. Will probably do every 5K miles or so. NO way I'd wait until 21K miles!!!
Old Aug 1, 2024 | 11:12 PM
GavinC's Avatar
Nor should you. The V8 service intervals are less than the other engine types. 16,000miles if memory serves. A full breakdown is in the user manual. Passport to service.
Old Aug 3, 2024 | 02:23 AM
Defendher's Avatar
21k oci is marketing and sucking up to the epa, not engineering. Remember that once the vehicle is sold and out of warranty it’s your problem, not theirs. They are pushing the limits of viscosity with ever thinner oil in high pressure engine applications, 5k oci is reasonable considering the other factors. I changed it first at 865 miles, then at 5k.
Old Aug 6, 2024 | 07:04 AM
Defendit..'s Avatar
Originally Posted by GCSchmidt
I did my 1st change at 1,000 miles then at 2,000 miles...and averaged between 5,000 and 7,000 miles now between changes. Currently at about 66,000 miles on my 2022 110 P300. BTW I do my own oil changes.
Did you remove everytime all your underplating ?
Consider the Fumoto drain plug
https://landroverforums.com/forum/20...-valve-119176/
Old Aug 6, 2024 | 07:06 AM
Jim 90's Avatar
My plan is to alternate - drain vs syphon.
