When I ordered my D90 P300s there was no option choice for the dark grey cross beam.
(only on x-dynamic you did have that choice)
So I bought the workshop manual and watched the video from Powerful.co.uk for the steering inlay change.
In my case there are 6 magnesium parts which I have had powdercoated in Interpon Noir 2100 Sablé YW359F
Started with the steering Wheel, disconnect the battery after last turn for removing the airbag.
Unbolted the seats to get access to remove the side panels of the console, 6 bolts under there,
Removing everything else exept the upper dashboard, managed to get the long Beam out at last.
the six parts of magnesium ready for getting powdercoated in my custom color
Collected my parts and started to reassemble the steering wheel
So after 5 hours everything bolted back in and torqued as spec the result:
Some more pictures by daylight
Disclaimer, do not start this mod if you are not mechanicly inclined.
Wow! Totally amazed that you went thru that effort to change the color!! That is dedication right there. You're inspiring me to make the changes that I think are as important to me.
