raised air intake utility?
I just checked my engine P400 V6 and noticed the airbox is on the driver side front of the vehicle. If I would install the raised air intake, where does it sucked the air when the airfilter box of the engine is sealed and is not in anyway connected to this airbox. So, is it just for aesthetics?
It’s a raised air intake (not snorkel) and from what I’ve read it’s functional and not just for show. There’s a lot of info on it. I’d like to install as well but unless they fixed the rivnut, I’m passing for now. I can install myself but not skilled or understand how to use the tool to correct the wrong size that comes in the package.
Watch the install and decide.
https://youtu.be/YPtR-d-WnqI
It's designed to reroute the air flow to force cooler dust-free air into the engine compartment. Improves torque (more oxygen), prevents fouling, improves mpg, and generally helps keep the engine, turbos, and other bitchy parts cooler and cleaner.
Wholly unnecessary on the highway but useful in dry, dusty, hot, sandy places where you're moving slowly. As if anyone will use their Defender like that.
Defender already has a wading depth that's probably never going to be exceeded by most owners. The rest will know what to do... buy a Series II.
@_Allegedly - Recommending a Series II?! At least start with the IIa.
@Count Laszlo - There's a LOT of things you can do to really F' up the L663. Installing a rivnut under the A-pillar trim isn't near the top of the list. Definitely something I would say to go for if you are reasonably handy. Buy a rivnut tool on Amazon. I think a best in class will set you back <$40. Then if you want to go mad, you can buy a CRAP load of nuts in various sizes for ~$20. More than used in a lifetime. For $30 you can pick up a good tool WITH more rivnuts than you'll ever need. Spend some time putting rivnuts into anything you have lying around. Most people never practice with a new tool and that's what F's things up. Grab new tool, put it to use, bad things happen. Spend some time with any metal lying around. Or beg, borrow, buy some sheet metal. You won't become a rivnut Zen master, but it doesn't take long to become highly proficient. Then save yourself hundreds of dollars instead of taking it to someone else who won't replace all the clips, screws and details that you care about. Good luck either way you have it installed! (Sometimes someone else saves me a TON of time).
The following 2 users liked this post by GrouseK9:
Count Laszlo (12-03-2022),
GavinC (09-22-2021)
It doesn't. It's not a snorkel.
like you link says, it is just cosmetic with no inherent purpose at all. the front grille provides enough airflow to the engine especially with its flat front.
For those saying it’s fake, which seems to be a debate, you could make some very light fabrications to seal it more against the body and the intake, not snorkel proof but I’d assume a reduction in air leakage.
GrouseK9 (09-22-2021)
Otherwise, I agree they are decoration.
You will see elsewhere on the forum that the mounting has been problematic and sometimes noisy.
The following 2 users liked this post by TrioLRowner:
GrouseK9 (09-22-2021),
_Allegedly (09-22-2021)
