Rattle From Engine Bay Under Acceleration
Old Jun 10, 2024 | 04:26 PM
richmeyer's Avatar
Default Rattle From Engine Bay Under Acceleration
Hey all, curious as to if anyone else has experienced this issue. Its now happened to me 3 or 4 times on my P400; when mildly accelerating from around 20 mph (think freeway on-ramp type acceleration) using about half-throttle, I'll get this quick series of rattles from the engine bay accompanied by a brief power loss. It's almost like it goes into a brief limp mode. If I continue to roll into the throttle, nothing happens, I don't get any more rattling but the truck also doesn't want to continue to accelerate. If I release the throttle and then give it 75% to 100% it will finally kick down and accelerate.
I'm not getting any kind of warnings on the dash or codes as far as I can tell.
Before I call the dealer for yet another service appointment I figured I'd see if anyone else had experienced this.
Old Jun 11, 2024 | 08:53 PM
nashvegas's Avatar
Sounds like engine knock, which is being detected by the fuel injection system/knock sensors, and thus playing with timing and fuel or whatever to pull back on power to protect the engine. Def have it looked at. Still under warranty?
Old Sep 12, 2025 | 06:41 PM
NorCal Defender's Avatar
did you ever get this sorted? I'm dealing with same issue, have an appointment next week.
Old Sep 16, 2025 | 08:10 PM
Coopaloop's Avatar
I heard mine rattle today...
Old Sep 19, 2025 | 12:33 PM
Mine is currently at the dealer to diagnose this issue. Road tested with the lead technician yesterday when dropping off and was able to duplicate it constantly on light acceleration around 1400-2000 rpm, it definitely sounds like engine detonation ping or knock. Hoping they'll get it sorted, but I'll report back!
Old Sep 19, 2025 | 04:32 PM
Coopaloop's Avatar
Thank you @jaredmonez@gmail.com !
Happy to hear about the the diagnosis....
Old Oct 5, 2025 | 01:43 AM
Well, the dealership went through may checks and found the electric supercharger causing the noise, (no codes) also found fouled spark plugs (only 10k on veh) they replaced all plugs and supercharger, took it home and noise still present. Dropped it back at the dealership, and they are still finding the noise to be coming from the supercharger when using chassis ears, another supercharger ordered and will be replaced. Looks like @DEFENDER2020 had a similar experience. Not convinced this will fix it, but I pray it does. Unfortunately I had to cancel my 3 day weekend getaway and LR experience.
Old Oct 8, 2025 | 12:21 PM
Coopaloop's Avatar
Hi @jaredmonez@gmail.com I just returned from my dealer and had both the service tech and salesman drive my P400 110, they both heard the noise. At lower rpms, say around 1500-2000 under load is when you hear the valves / timing chain kind of slap another metal part. The tech said it is the VCT (Variable Camshaft Timing) and is a NORMAL(?) sound.
For precaution, my car will go to the dealer as the tech said there could be hidden codes that are not showing up on the screen at start up etc...
I can live with the sound now knowing it is considered normal, however bringing the car in for me at least, is beneficial to starting a history of a potential, future issue.
Old Oct 8, 2025 | 12:32 PM
Thats interesting they consider it normal, I agree it's timing related but sure seems to me the noise is detonation, that's not good. So they're saying the vct system hardware (solenoid , cams, or actuators) themselves are making the noise, it's not pinging? I really Appreciate the update and feedback! After the dealer replaced the second supercharger the noise is still present so they've now ordered new vct actuators. I suspect the noise will still be there, but we'll see what happens. Documenting the concern is key so at least there's a record of it, especially since they've duplicated it, heard it, and can state they feel it's normal characteristic of this engine model.
Old Jun 3, 2026 | 05:22 PM
JP Defender's Avatar
5th Gear
NorCal Defender - Did you ever figure out what was causing your noise?
