Rear (cargo) door issue this morning
Old Aug 16, 2022 | 05:09 PM
  #21
NoGaBiker's Avatar
Originally Posted by Dan Hairy
I did think about putting my button in there when I was adding the extra power outlets but decided against it as I have the rear table installed, instead I put mine in the interior handle recess, it's shown on the end of this short video https://youtu.be/Nf66UaCqR8M
Originally Posted by GrouseK9
@Dan Hairy - THAT was brilliant. I may find myself doing that once I open it all up to put in the interior door switch.
Huh??? What button are you talking about? This thread is about the tailgate door holding or not holding on an incline. I don’t understand the button you are installing? I just reread the thread and there’s no mention of a button you have to add until Parukas reanimated the thread yesterday with talk about where he put a button. I’d write it off as somebody stumbling into the wrong thread to post their info, except two of you agreed with him and talked about where you put your button. So now I’m really confused.
Old Oct 13, 2022 | 08:56 AM
  #22
Groshyubcha's Avatar
8th Gear
Today I discovered that the door will hold in place when you push it back to the desired location hold it for one second and then gently release (and it holds w/o squeezing the door handle etc). BUT on an incline(when I need it most) it tends to not hold though. Additionally the slightest jarring of the car and the door closes on its own. Maybe somethings wrong with my strut?
if I open the door half way, hold in place, and then release it will hold. Anything beyond half way it holds for a split second and then closes.
Old Oct 13, 2022 | 12:52 PM
  #23
Nick4's Avatar
I am just as confused as you are and still hoping for an answer!
Old Oct 13, 2022 | 03:50 PM
  #24
dj200's Avatar
I believe the button in question is the one behind the door handle.
On my ‘22 P400 with soft close, if you push that button with the door open, the door-lock mechanism will click and the door will hold that position until a significant force is applied. Works on side-slopes.
Old Oct 14, 2022 | 06:46 AM
  #25
MattF's Avatar
On my MY23 110 it also operates this way. The handle button you squeeze to open the door if clicked again will keep the door in the current position. It then needs to be clicked again (as if you were opening the door) to move it. (no soft close capabilities on mine)
Broken08
Apr 3, 2022 10:27 AM
Jaykeim
Jul 13, 2017 07:38 PM
RTacc
Dec 23, 2015 08:18 AM
4ruf
Sep 29, 2015 01:27 PM
CANAMDiscovery
Jan 30, 2010 09:20 AM
