Can't open my Cargo door from inside or out.
Old Jul 12, 2017 | 04:21 PM
Jaykeim's Avatar
Default Can't open my Cargo door from inside or out.
I just bought a 99 Discovery 2. I cannot open then cargo door from the outside or the inside. No amount of fiddling or combinations of unlocking, pulling up on the door lock as you try to open works. I popped the rear door cover off but can't see what I need to do. Any help would be nice!
Thanks,
jay
Old Jul 12, 2017 | 04:26 PM
ReceptionRover's Avatar
Sometimes dirt can get in there and lock things up. Pop off the cover, spray some WD40 on the latch mechanism while squeezing/working the door latch (on the outside). Hopefully this will fix the issue. Just remember to put hold a towel against the door so the WD40 doesn't spray all over. If that doesn't work let us know and we'll take it from there.
good luck and welcome to the forum!
Old Jul 12, 2017 | 04:27 PM
LR03NJ's Avatar
Thanks,
jay
Rust probably? If then, bend and insert WD40 straw inside the hole in the outside door handle. Let it sit for a while and try again. Open as if theres no tomorrow.
Old Jul 12, 2017 | 04:40 PM
OverRover's Avatar
+1....have at it >
Old Jul 12, 2017 | 05:06 PM
No Doubt's Avatar
Just to add to the above, there is a child lock tab switch on the inside of the hatch that will prevent you from opening the back hatch from the inside if it is engaged (down). Just flip it up to enable the inside hatch handle to operate.
It's unlabeled on my D2, but up near the actual lock mechanism almost on the side edge.
Old Jul 12, 2017 | 05:56 PM
OffroadFrance's Avatar
X1 ........... this way it normally works.
Old Jul 13, 2017 | 05:44 PM
Alex J's Avatar
This fixed mine when I got my D2 at the end of winter. I didn't know there was a video of the fix, I just noticed that the handle was sticking and lubed the pivots and it has been fine since.
Old Jul 13, 2017 | 07:38 PM
mln01's Avatar
Did it open when you were looking at it before you bought it?
joshp01
Dec 5, 2021 07:50 PM
ccarman12
Oct 18, 2013 11:51 AM
